Old 12-29-2005, 10:59 PM   #1 (permalink)
Check the welds on your doors!
I was in the process of correcting a problem the tint installers caused on my doors when I noticed one of the welds on my driver's door was poorly done. As a result, there is a noticeable gap in the weld and the paint has cracked and is starting to show signs of rust. I'll be taking it into Honda soon to have them fix this before it gets out of hand but I thought other Civics might have the same factory defect and it's a good idea to fix it now before the rust starts to spread. My passenger side door was fine. I have an EX Coupe.
medcina is offline   Reply With Quote
Old 12-29-2005, 11:07 PM   #2 (permalink)
ncoday's Avatar
Interesting, there will always be "goofs". I also have an EX coupe, so I will checking my doors tomorrow when it is sunlight outside. Thanks for the headsup.
Personally, I would request whole new doors as there is no telling what kind of damage lies beneath??
ncoday is offline   Reply With Quote
Old 12-30-2005, 10:02 AM   #3 (permalink)
CivicWithNav's Avatar
there is rust on bottom front door due to POOR welding job.
Old 01-08-2006, 04:34 AM   #4 (permalink)
ncoday's Avatar
Update on what the dealer said/did??
Old 01-08-2006, 05:11 PM   #5 (permalink)
my sedan had a problem with the door closing tightly, it would close halfway, latched but not airtight. It took twice the force to close properly as the other doors on the car. My dealer fixed it though, now I'll check the welds.
basmoq is offline   Reply With Quote
Old 01-08-2006, 06:03 PM   #6 (permalink)
Can't give an update since I haven't had time to take it in yet. Not sure when I'll be able to take it in since I need the car for the next few weeks but will try to take it in ASAP.
Old 01-09-2006, 12:46 PM   #7 (permalink)
finally got around to looking at both of mine. Def not the prettiest welds, but neither are really bad. Both are gobbed up around the whole seam, like the right side of this picture of yours.
C17chief is offline   Reply With Quote
Old 01-09-2006, 07:32 PM   #8 (permalink)
burbley's Avatar
I looked at mine to see what it looked like. Feel the joint with your finger. I think you'll find that the cracks or yellowing that you see is actually the putty used to airseal that joint. That joint is two sheet metal pieces slipped together and then putty sealed.
burbley is offline   Reply With Quote
Old 01-09-2006, 10:24 PM   #9 (permalink)
Nope it's definitely rust. I know what you're talking about with the putty and I saw that too but the yellow in my picture above was definitely rust because it had spread and caused the paint to start chipping since I posted that picture. Since I can't be without the car for a few days while the dealership fixes it and since I don't trust the dealer to actually fix the problem correctly I did what any good owner would do and took matters into my own hands. I used a very small screw driver and carefully started chipping away the paint that was peeling off until I reached the end of the rust and there was nothing but bare metal. This turned out to be an area about 2 cm by 2 cm (not exactly a square). I then took some VERY fine sand paper and wrapped the small screw driver with it and sanded the very minor surface rust that was there until I had nothing but bare metal in the entire area. Then I used a toothpick to carefully dab some gray Rustoleum automobile primer to the entire area. It's drying now and should be good to go by tomorrow and the rust should be under control now. I have the touch up paint on order and will be covering the primer with it when I get it. As it is now you'll be hard pressed to notice the spot since the primer is close in color to the silver paint and of course it's in a not-too-visible area.
Old 01-11-2006, 02:57 AM   #10 (permalink)
HardBoiler's Avatar
checked mine on both sides..they seemed to be fine...maybe mine was the later production model...never had the padel problem either.
HardBoiler is offline   Reply With Quote
Old 01-11-2006, 09:01 AM   #11 (permalink)
I'm sure it was probably just a fluke with my car. Mine was built in late November and delivered mid-December so it wasn't a very early run either. No biggie. It's fixed now so I'm not concerned. I got the touch up paint and painted over the primer and it looks as good as the rest of the area...which is to say that it looks like a big fat blob of weld painted over. :)
Old 01-14-2006, 10:28 PM   #12 (permalink)
White06's Avatar
I have the same issue, I thought I was alone. Let me know what the dealer says, I was going to have them look at it when I take it in for oil/recal on the gas pedal.
White06 is offline   Reply With Quote
Old 01-14-2006, 11:15 PM   #13 (permalink)
I didn't take it into the dealer and fixed the problem myself. It's rather easy to fix as long as you don't wait too long and let the rust spread.
Old 01-19-2006, 03:26 PM   #14 (permalink)
peliROJO's Avatar
You are correct. I felt that joint and it felt soft. It's putty that has been painted over. Not a weld.
peliROJO is offline   Reply With Quote
Old 01-19-2006, 03:38 PM   #15 (permalink)
Perhaps in your case. But putty doesn't spread and crack the surrounding paint and it doesn't come off when sanded down to reveal bare metal underneath. I definitely had rust forming and the blob on mine is definitely a weld since I sanded it down to bare metal and repainted it too.
Mis shipped of 12 Civic's 8thwonder Introduction & Pictures 13 10-22-2005 05:25 PM
Halloween Jokes.... pigman Water Cooler 2 10-06-2005 03:10 PM
Car and Driver article "Cheap speed round 23" acura rsx-s versus 4 cars 02boostlessVIC Garage 2 09-13-2005 01:54 PM
