Old 04-03-2007, 10:19 PM   #21 (permalink)
SiAzul's Avatar
Mario
Originally Posted by fiji06si13
here is how it goes....you have 10k on the car I'm guessing that you never added coolent to your car since you got it...every 5k check it cause it evaporates like water.
It probably was a little low when you did the job.
You took the line off that was in the way to do the CAI......
when you do this you create an air bubble in the system...you introduced air into the system...
You filled it to the fill line ...
Next you should have ran the car for a while with the heat all the way to the hot position.. this opens the coolent system up so the air can circulate through the system to the overflow bottle if you didnt do this the air might have gotten trapped by the thermostat on your engine causing the temp to go up...when it opened the temp went down and air passed through.
the burning smell if there was no steam might have been the rubber hoses getting hot.....no biggy kind of normal....
the coolent cooled down and was low because air bubble passed through and into resevoir if you added coolent run car let it reach operating temp check for steam or leaks
then 2 morrow check again for any leaks and see if the coolent is low...
WILL DO, Ill update tomorrow thanks for all the help
SiAzul is offline   Reply With Quote
Old 04-03-2007, 10:21 PM   #22 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
Lightbulb
no prob check for leaks!
put coolent 2 morrow right at full line no lower no higher..
no problem at all my fellow fiji owner
Originally Posted by ryker View Post
intial quality should be good when you spend 20K or more on a car. If I buy a 30.00 Polo shirt I damn well expect the buttons to stay put.
Originally Posted by fiji06si13 View Post
Well said..... now relay that message to honda......
RIP Bernie Mac
fiji06si13 is offline   Reply With Quote
2006 Honda Civic Engine Information webby Garage 6 11-21-2008 04:23 PM
2006 Civic Engine: I-VTEC webby Garage 8 10-16-2007 12:54 AM
Nitrous 101 FG*SQUAD Nick Forced Induction And Nitrous 22 05-26-2007 02:50 AM
2006 honda world news webby Garage 0 07-25-2005 10:31 AM
