Shift Lock Release -help!
My girlfriend's got a 1997 Acura CL V6. Today the "Shift Lock Release" became engaged for what appears to be no reason. That causes you to not be able to shift out of P without a spare key being inserted into the shift lock release hole.
What would cause this and what are the fixed? Thanks....
#5 (permalink) | |
Holy Crap!!!™
This could be the brake sensor by the pedal as suggested (if it doesn't recognize your foot is on the brake it won't let you release the shifter from park)
Could also be the shift lock release sensor inside the console. Not sure about the CL but this is where it is in the Integra. Ever have problems getting the key out of the ignition? I was having this intermittently in my Integra in cold weather and people kept telling me it could be my ignition switch..... When we got those two weeks of zero weather I couldn't get my shifter out of park either. I finally put the two problems together and noticed when this was happening the "P" light on the dash wasn't lighting up. If I would would wait a few seconds (or jiggle the shifter) the P light would come on and I could move the shifter and also get my key out of the accessory position. It could be a loose or dirty connection, you could try that first. With some research I found this is a problem with a lot of older Integras so I just bought the switch for around $59 from Acura. It's a real PITA problem that I don't want to deal with next winter. |
#9 (permalink) | |
#10 (permalink) | |
Holy Crap!!!™
The switch sends the signal telling the computer that you actually pressed the brake to change gears. If the switch is faulty it won't send a signal and you won't be able to get the car out of park. |
