Old 04-01-2007, 01:14 PM   #1 (permalink)
06si's Avatar
Kenny G
Oil meter
So my oil meter came up saying I have 15% oil left.
The actual message was B2 (or 2B) 15%.
Can somebody tell me what the B2 means. Does it mean that there is something else wrong with the car?
06si is offline   Reply With Quote
Old 04-01-2007, 01:21 PM   #2 (permalink)
n00b retro whore
ethlar's Avatar
B2 is a maintenance minder, its indicating youre due for a service, details can be found in your manual
Old 04-01-2007, 01:22 PM   #3 (permalink)
Kevin's Avatar
Main Item B/B1
* Replace engine oil* and filter.
* Rotate tires,** inspect for wear and adjust pressure
* Service front and rear brakes.
* Inspect parking brake adjustments.
* Inspect tie rod ends, steering gear box and boots.
* Inspect suspension components.
* Inspect driveshaft boots.
* Inspect brake hoses and lines (including ABS)
* Check all fluid levels, condition of fluids and check for leaks.
* Inspect exhaust system.
* Inspect fuel lines and connections.
Sub-Item 2
* Replace air cleaner element.
* Replace dust and pollen filter.
* Inspect and adjust drive belt.
http://honda.ca/HondaCA2006/YourHond...TrimID=263&L=E
Kevin is offline   Reply With Quote
Old 04-01-2007, 02:08 PM   #4 (permalink)
06si's Avatar
Kenny G
cool. Thanks for the hlep
Oil Life Elmacho Civic SI 32 12-02-2008 03:01 PM
Oil Change DIY ethlar Engine 251 12-01-2008 10:46 PM
THE OIL FAQ - synthetics, intervals, weights, brands jdrumstik Mechanical Problems & Technical Chat 98 10-16-2008 01:53 PM
oil life meter Randyg75 Garage 12 10-03-2006 09:24 AM
