Old 04-12-2007, 10:12 AM   #21 (permalink)
Rems07si's Avatar
Remy
change them or get them cut ASAP
Rems07si is offline   Reply With Quote
Old 04-12-2007, 10:58 AM   #22 (permalink)
tommyroo's Avatar
Go back to your dealer and tell them you either want them to fix the breaks or put it in writing that they are fine. If they choose the "they are fine" path again. Tell them in no uncertain terms that if and when the brakes fail you will sue the living crap out of them.
tommyroo is offline   Reply With Quote
Old 04-12-2007, 06:08 PM   #23 (permalink)
Dude, did they at least lube up first? Hell no that's not normal. Can't you tell by comparing them with the front rotors? I have that many miles, and all 4 of my rotors look like mirrors, and I HAVE been through nice salted roads up here. HOWEVER, are we looking at both rotors or just one? How deep are those scratches? Are they surface imperfections or deep grooves - hard to tell depth in a 2-D picture. Here's what I would do: Pull the pads, see if there's anything lodged in there, and get an idea of how deep those grooves are. If it's a defective rotor, I would follow up with Honda. If it's road debris or something else, get it resurfaced or get another one. They're what, all of $75?
undrgnd is offline   Reply With Quote
Old 04-13-2007, 02:32 PM   #24 (permalink)
Lilwolvy3's Avatar
Well this is the deal, both sides look just like that. Those are pictures of one side, but they look almost identical. I will bring it to another dealer in a couple weeks when I get a chance. I am still under 3k miles and I understand that there is no way these rotors should look like this. I know they should be almost perfectly smooth and at 2,800 miles they should look perfect. I figure they do have it on record that I brought it in and they said it was fine??? Not sure about that. Anyway, I will bring it to another dealer because there is no way should have to buy new rotors for a car that is just over a month old that I haven't even changed the oil on yet. Thanks for all of your replies on this matter.
Lilwolvy3 is offline   Reply With Quote
Old 04-13-2007, 02:44 PM   #25 (permalink)
Take it to a service place and get that checked out! Do it sooner than later. You might have to get new brakes - rotors and pads. Or might have to grind them down a bit if it's not too deep!
Good luck! Also take it to Honda to see if it's a defect.
bung_goo is offline   Reply With Quote
Old 05-11-2008, 12:21 AM   #26 (permalink)
Lilwolvy3's Avatar
I know this thread is over a year old, but I just wanted to update it. The dealer never did replace the rotors and now my car has 23,000 miles on it. The rotors are now perfectly smooth. I don't know what caused this in the first place, but whatever it was now it is fine. Just a heads up for anyone else that may come across this in the future.
ROTORA Slotted Rotors and Big Brake Kit Sale: Civc Si 06+ Only Excelerate Excelerate Performance 41 02-07-2008 04:09 PM
Need Help!!!!! 3rd Brake Light!!! cornerstrike Inside and Out 12 11-13-2007 01:15 AM
Powerslot Big Brake Rotors! Z1 Performance Z1 Performance Inc 39 03-16-2007 09:29 AM
dealer pissing me off - brake noise after B maintenance NoMoreHonda Mechanical Problems & Technical Chat 11 10-23-2006 09:15 AM
