Old 12-22-2005, 02:54 AM   #1 (permalink)
CivicWithNav's Avatar
Poly-Fill trunk area
I haven't really FULLY tested this idea/theory but here it is
POLY-FILL u buy at crafts store and whatnot
since the civic is the lowest class of honda, it lacks some insulation in the trunk lid and around it(the whole car really) So I purchased 2 bags of poly-fill and shoved them into the openings in the trunk lid hoping to reduce some vibration from speakers and reduce noise coming into the cabin. I also put some in the rear quarter panel area as well as the rear deck(from trunk area) and subwoofer
i haven't had the music up too loud but seems like it's working. less vibration to the outside trunklid.
I also had a chance to take the stupid rear deck out and put it back...I think I fixed the rear deck rattle which was driving me crazy!
try it out I think it's a CHEAP mod that can be benefitial.
Old 12-22-2005, 05:31 AM   #2 (permalink)
www.yospeed.com
Celcius's Avatar
David Yonehara
Thanks for the tip! Less rattle is something you can't put a price on.
Is it more or less safe in most conditions? Any nasty fumes or problems with it when you were applying it?
Celcius is offline   Reply With Quote
Old 12-22-2005, 09:16 AM   #3 (permalink)
naw it's what you put in the dolls ...and it said non-toxic, washeable and etc... so it should be ok
Old 12-22-2005, 07:20 PM   #4 (permalink)
I did this with a 93 accord to stop the sub from rattling the whole car. It totally did the trick although I worried about a fire and made sure to keep all bulbs away from the polyfill.
Igotsoul4u is offline   Reply With Quote
Old 12-29-2005, 05:33 PM   #5 (permalink)
I wonder if there is a similar 'stuffable' type sound deadening material out there instead of sheets like dynamat and the like. Some real stuff meant to get rid of noise.
C17chief is offline   Reply With Quote
Old 01-05-2006, 02:44 AM   #6 (permalink)
Use polyfill.
http://www.partsexpress.com/pe/showd...number=260-317
Old 01-08-2006, 05:08 PM   #7 (permalink)
hmm, never stuffed my box before, I guess I should consider it
basmoq is offline   Reply With Quote
George Bush Sound Board webby Water Cooler 2 08-16-2005 04:02 PM
Useless Fact of the day 2- Tues Prototype Water Cooler 2 08-09-2005 06:03 PM
All the posters you ever wanted C2i0v0i1c Water Cooler 2 07-13-2005 09:33 PM
UltimatuM C2i0v0i1c Water Cooler 4 07-13-2005 01:52 PM
