Closed Thread
Old 03-25-2007, 04:58 PM   #1 (permalink)
Possible to turn off seatbelt warning?
I didn't see anything under the Search function regarding this - just wanting to know if anyone has found a way to disable the loud beeping warning we get when we remove the seatbelt while the car is in motion. One of the only complaints I have for the car.
gwsharksi is offline
Old 03-25-2007, 05:34 PM   #2 (permalink)
fg1coupe's Avatar
SEARCH BEFORE YOU POST SOMETHING STUPID
fg1coupe is offline
Old 03-25-2007, 05:37 PM   #3 (permalink)
07Sin4Door's Avatar
Dan
eeek ^
07Sin4Door is offline
Old 03-25-2007, 05:48 PM   #4 (permalink)
qwerty :)'s Avatar
kyle
Seat belt warning beep
qwerty :) is offline
Old 03-25-2007, 05:52 PM   #5 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
How about not removing your seatbelt while you car is in motion.. Then you won't have to worry about the seatbelt reminder beeping...
Ruthless909 is offline
Old 03-25-2007, 05:53 PM   #6 (permalink)
honda06si's Avatar
justin
wow. you my friend are a retard
honda06si is offline
Old 03-25-2007, 05:53 PM   #7 (permalink)
I searched...the function didn't help me much. Probably my fault, but at any rate, thanks to qwerty for providing a link. Thanks to fg1coupe for nothin'.
Old 03-25-2007, 05:55 PM   #8 (permalink)
Quite true....but there are times it is needed (kids in the back, acting the fool, usually).
Most of the time, we leave the belts on. But my girlfriend gets a splitting headache if she has to remove it, and the beeping begins.
Old 03-25-2007, 05:55 PM   #9 (permalink)
honda06si's Avatar
justin
fg1coupe wasnt in the wrong for telling you to search because there have been threads about this. however he was wrong for calling you stupid for one. and having the damn caps lock on for two.
Old 03-25-2007, 05:57 PM   #10 (permalink)
Ahhh! Domokun!
4dr WhOrE!!!
fg1 coupe is a TARD... just plain and simple...
Old 03-25-2007, 06:02 PM   #11 (permalink)
qwerty :)'s Avatar
kyle
your welcome :)
and it probably took me less time to give you that link, then it too for fg1 to figure out typing in caps
Old 03-25-2007, 06:03 PM   #12 (permalink)
Right you are, Honda06si. As I said, it's probably my fault - I was in a rush, and didn't utilize the Search function properly, I'm sure.
Old 03-25-2007, 06:06 PM   #13 (permalink)
honda06si's Avatar
justin
from what i can see your new to the site and only have 11 posts. and it took me alot longer than that to figure everything out. try to go to advaced search and if your looking for something specific. check the box that says in thread titles only
Old 03-25-2007, 06:07 PM   #14 (permalink)
Typical. How Typical.
Special Ringpop's Avatar
I see some people want to turn this board into another clubsi.
It's not going to happen. If you don't want to reply to this guy's thread, shut your mouth and don't respond.
God some of you...
Anyways, simple solution. Wear you're seatbelt.
Special Ringpop is offline
Old 03-25-2007, 06:20 PM   #15 (permalink)
esx005's Avatar
jeremy
use yiur spare key.it will stop the chime,but it is easier to wear the belt
esx005 is offline
Old 03-25-2007, 06:30 PM   #16 (permalink)
honda06si's Avatar
justin
i switch keys all the time. mine doesnt stop
Old 03-25-2007, 06:35 PM   #17 (permalink)
esx005's Avatar
jeremy
no, my bad, what i was trying to say was jam your spare key in your setbelt.it sticks just right and stays,sounds dumb but if someone is that concerned about the chime and doesn't want to wear their seatbelt, then dumb shouldn't matter
esx005 is offline
Old 03-25-2007, 06:54 PM   #18 (permalink)
BATANG CITY JAIL's Avatar
why the hell you want to turn that seatbelt signal off?? you dont want to put the seatbelt??
BATANG CITY JAIL is offline
Old 03-25-2007, 06:55 PM   #19 (permalink)
esx005's Avatar
jeremy
not me but someone else ?????
esx005 is offline
Old 03-25-2007, 07:06 PM   #20 (permalink)
^^ yupnotyou...
Closed Thread
Can you turn off the Seatbelt warning beep? Dax I.C.E., Electrical, Security, & Navigation 15 10-12-2007 12:37 PM
Seatbelt mangled dextor Mechanical Problems & Technical Chat 2 03-15-2007 11:03 PM
cant turn the wheel!!! bboylocob Mechanical Problems & Technical Chat 64 01-03-2007 08:14 AM
seatbelt sticking CrAsian Mechanical Problems & Technical Chat 4 12-28-2006 02:12 AM
How to achieve the tightest turns? How much do you turn your steering wheel? dlux200sx Civic SI 10 10-24-2006 07:43 PM
