Old 03-21-2007, 11:59 AM   #1 (permalink)
Seven
Question what's wrong with my car?
It seems something is wrong with the transmission module?
We've found about ten cars have this issue.
pic @2600+ KM
Seven is offline   Reply With Quote
Old 03-21-2007, 12:03 PM   #2 (permalink)
Check the TSBs. The 06 Civics with the R18 motor need to have a gasket replaced to fix the oil leak as some of the bolts were not torqued correctly during assembly.
blueroadster is offline   Reply With Quote
Old 03-21-2007, 12:18 PM   #3 (permalink)
Seven
it seems transmision fluid is leaking, not the engine oil?
I'm not sure if the TSB mentioned the same issue?
Thanks anyway!
Could you give a URL for the TSBs? :P
Old 03-21-2007, 08:15 PM   #4 (permalink)
iknowmysh1t's Avatar
looks like you need a new tranny!
iknowmysh1t is offline   Reply With Quote
Old 03-21-2007, 10:14 PM   #5 (permalink)
Damn that looks bad. I hope it's not as bad as the photo really shows.
Old 03-21-2007, 10:19 PM   #6 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
Possibly your power steering pump is leaking...
Ruthless909 is offline   Reply With Quote
Old 03-22-2007, 08:20 AM   #7 (permalink)
Seven
where's the power steering pump?
Old 03-22-2007, 07:51 PM   #8 (permalink)
pwr steering pump is on the other side. cant be that
Old 03-23-2007, 01:26 PM   #9 (permalink)
Mateen's Avatar
Its the transmission. I had the exact leak.
Mateen is offline   Reply With Quote
Old 03-23-2007, 01:29 PM   #10 (permalink)
esx005's Avatar
jeremy
if you had the leak did honda fix it.
post more info on your situation
esx005 is offline   Reply With Quote
Old 03-23-2007, 01:29 PM   #11 (permalink)
Vince's Avatar
Stephen "Vince" Carter
If I'm not mistaken, you've definitely got some fluid leakage there. You should get that checked out, ASAFP. Don't drive it!
Vince is offline   Reply With Quote
Old 03-23-2007, 01:33 PM   #12 (permalink)
Dessa_8837's Avatar
Shayne Dessa
I would'nt drive it if I was you, get it checked out!
ShayneD.
Dessa_8837 is offline   Reply With Quote
Old 03-23-2007, 01:35 PM   #13 (permalink)
Mateen's Avatar
Yes they did. It was a seal or gasket from the drive shaft going from Tranny to the left wheel. Mine was not that bad. I noticed it when I had 3000 miles on the car. It was probably leaking from the day one. I think I caught it soon enough. They said they will fix the leak and if it comes back, they will have to put a new tranny in there which kind of scared me. Come to think of it, I need to to Jack up my car and check it again to make sure the leak has not come back. I now have 6000 miles. ex coupe auto 06.
Old 03-23-2007, 11:00 PM   #14 (permalink)
Seven
pic @5000+ KM
Old 03-23-2007, 11:19 PM   #15 (permalink)
Seven
they cleaned & added ointment to the bottom of transmission as they're suspecting it's leaking there.
Old 03-23-2007, 11:21 PM   #16 (permalink)
Seven
could you please show me the pic of "Tranny". I don't know what it's exactly.
BTW, why did replacing a new Tranny scare you?
Old 03-24-2007, 04:11 AM   #17 (permalink)
Mateen's Avatar
Got no pics. Mine was about the same area as the pic on post #14.
They put dye in my transmission and thats how they could pinpoint where the leak was comming from. You need to know where the leak is originating from.
Old 03-24-2007, 06:24 PM   #18 (permalink)
Mateen's Avatar
pic @5000+ KM
The pic at 5000+KM looks cleaner than the pic at 2600+KM. So I'm assuming that they fixed the problem at 2600KM and it came back at 5000KM? Could you give more detail?
Old 03-24-2007, 11:21 PM   #19 (permalink)
Seven
actually they did not fix anything but to clean the leaking oil. 5000+ KM is better than 2600+KM, maybe becuse the speed of leaking is stable now, who knows. They're still diagnosing where the leaking is from?
I'll keep you posted if any update.
Old 04-02-2007, 03:46 AM   #20 (permalink)
Seven
I've got some more pictures which were shoot @6600 KM.
The dealer checked the leaking fluid and sent a report to the manufacture to ask for a replacement of the transmission module.
car show and bbq in fresno california civic_06_si California 5 03-23-2008 06:37 PM
Yet another car washing guide... CoryB Detailing 18 09-15-2006 10:23 PM
Personal experience on ways to get the best deal out of your car purchase. graciextobie Driving Experience 40 07-07-2006 12:27 PM
Who's right, and who's wrong!? !@#$% ScorchedHands Civic SI 24 03-27-2006 06:29 AM
