Safe to lube clutch pedal rod? - 8th Generation Honda Civic Forum
Old 06-05-2013, 02:12 PM   #1 (permalink)
KevinMcC's Avatar
Kevin
Hey all I have a slight clicking noise in my 2009 civic si and was reading to lube the spring and also the actual push rod that goes into the master cylinder.
I was wondering if I spray white lithium grease onto the rod. Would any grease creep its way and contaminate the clutch fluid?
KevinMcC is online now
Old 06-05-2013, 02:18 PM   #2 (permalink)
Yep, perfectly fine to do so. Won't contaminate anything. I plan to do the same this weekend with lithium grease spray on my '08 EX.
See this thread, especially post #53:
06 Civic Si Popping Noise From Clutch
MardiGras is offline   Reply With Quote Quick reply to this message
Old 06-05-2013, 02:34 PM   #3 (permalink)
KevinMcC's Avatar
Kevin
Yup thats where I got the suggestion from, was just making sure, since no one confirmed.
Thanks!
KevinMcC is online now   Reply With Quote Quick reply to this message
Old 06-05-2013, 02:48 PM   #4 (permalink)
Definitely nothing to worry about, because the clutch fluid is contained in a closed hydraulic system that cannot be contaminated by merely lubricating the rod.
Basically, the clutch converts the mechanical (non-hydraulic) pressure applied by your foot (via the clutch pedal and the rod) into hydraulic pressure via the master & slave cylinders.
Old 02-28-2014, 07:56 PM   #5 (permalink)
Justin
id be weary using white lithium based products. its known to eat away and wear down plastic and rubber bushings. my suggestion would be to use either silicone spray or an actual solid hi-temp grease. honda makes a special grease called urea grease for specific parts like clutch pivot. check it out, it worked great for me
06SIcable is offline   Reply With Quote Quick reply to this message
Old 03-01-2014, 10:14 PM   #6 (permalink)
Steve
UREA Grease # 08798-9002
carpayments4life is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
clutch rod broken?? FG2NME Clutch & Transmission 1 12-29-2009 01:15 PM
broken clutch rod? FG2NME Mechanical Problems & Technical Chat 2 12-28-2009 04:55 PM
Clutch pedal. Same a s a dead pedal. CivicEX Civic SI 38 12-09-2009 06:05 PM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
