Hidy Ho Neighbor
Si - No adjustability on rear suspension!
I ran through a pothole a couple of weeks ago, which damaged my front right tire. I brought it into the dealer last Saturday, and they replaced the tire. I also asked them to look at the alignment, which they did. They found that the toe and camber were way out on my right rear, and told me there is no ability to adjust this. I would have to schedule with their body shop to get an estimate to replace some/all of the suspension components. I called and talked to their tech there, and he said this could potentially cost me near $1000. I said that this was fishy since I had no tire/rim damage on that corner. He said that the components are "very weak", and he was not surprised.
I will keep you posted on how this goes since I now have an appointment for next Monday, March 26th for them to look at it and give me an estimate.
#3 (permalink) | |
#4 (permalink) | |
#5 (permalink) | |
Hidy Ho Neighbor
#6 (permalink) | |
Tuna Fiddle
rear camber is adjustable as far as I know. I had my si up on the lift this past saturday and there is an excentric (sp) bolt that to me looks like it adjust rear camber. there isn't alot of adjustment there but they should be able to try and fix it before they tell you you need $1000 worth of work. I would get a second opinion. Oh and the skunk 2 upper arms are adjustable and are a pretty good investment if you ever do any track driving or have a lowered car.
#11 (permalink) |
This thread shows the Skunk2 camber arms as well as the stock ones. From the stock PICs, you can see that there is no way to adjust the rear camber.
#12 (permalink) |
The deale rshould know this but
"The suspension can be adjusted for front camber, front toe, and rear toe. However, each of these adjustments are related to each other. For example, when you adjust camber, the toe will change. Therefore, you must adjust the front wheel alignment whenever you adjust camber or toe." |
| Megan H-Brace and lower rear brace Review | 604_ep3 | Suspension and Brakes | 42 | 09-25-2009 06:22 PM |
| noise from rear... hfp suspension and progress rear sway bar | rippars | Mechanical Problems & Technical Chat | 8 | 07-01-2008 09:42 PM |
| a clicking noise/rubbing noise in the rear suspension of SI | radiocontrolhead | Mechanical Problems & Technical Chat | 15 | 11-23-2007 02:14 PM |
| LX Coupe Rear Suspension Issue/Noise | leenangle | Civic Coupe And Sedan | 0 | 07-27-2006 03:22 PM |
| Rear suspension area making slight sound | NBCivic | Mechanical Problems & Technical Chat | 1 | 06-01-2006 07:07 AM |
