Old 03-17-2007, 09:07 PM   #1 (permalink)
catchx34's Avatar
Transmission fluid change
For those of you who changed your MTF, did you notice that you had a slight leak where the engine and transmission connect? I changed my mtf today with amsoil and noticed the small leak and was wondering if anyone else noticed it.
catchx34 is offline   Reply With Quote
Old 03-17-2007, 09:14 PM   #2 (permalink)
bump..
irichard is offline   Reply With Quote
Old 03-17-2007, 09:20 PM   #3 (permalink)
Drunk'n Member
Sprecher's Avatar
I just did a MTF change today. I didn't notice a leak.
06 Habenaro Red Si w/navi
http://members.cardomain.com/sprecher
Sprecher is offline   Reply With Quote
Old 03-17-2007, 09:24 PM   #4 (permalink)
SiLvErLIgHT06's Avatar
Out of the blue question, what does one need for a MTF change?? Replace drain plug??
SiLvErLIgHT06 is offline   Reply With Quote
Old 03-17-2007, 09:27 PM   #5 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
theres a diy that tells you what you need.
Zeuceone is online now   Reply With Quote
Old 03-18-2007, 09:59 AM   #6 (permalink)
catchx34's Avatar
***ttt
Old 03-18-2007, 02:02 PM   #7 (permalink)
Smoother shift
dextor is offline   Reply With Quote
Old 03-23-2007, 12:43 PM   #8 (permalink)
Im Not Going Anywhere!!
CrackThatTec45's Avatar
you sure you didnt just have a little over-drip left over that puddled somewhere on the frame and just kinda creeped its way down after a while?....try whipping everything down and give it a little bit then check back before heading to the dealer. That happend to me when i changed my oil, freaking oil filter left puddles everyone!!! took me close to a week to finally stop dripping
CrackThatTec45 is offline   Reply With Quote
Old 03-23-2007, 12:52 PM   #9 (permalink)
Nacho Cheese!
letsgoflyers81's Avatar
I didn't have any leaks. Like others have had, my transmission was overfilled from the factory so a lot of fluid poured out once I removed the fill bolt, but there was no leakage.
letsgoflyers81 is offline   Reply With Quote
Old 03-24-2007, 10:33 PM   #10 (permalink)
catchx34's Avatar
I saw potential leaks around the gasket where the tranny and engine are mounted and around that small black cover under the transmission. Hopefully it was just some old oil that splashed.
ATF fluid change ajrich Do It Yourself Articles 8 03-11-2007 04:07 PM
Any way to check the transmission fluid? hiphopaddict Mechanical Problems & Technical Chat 8 01-15-2007 05:18 PM
Change trans fluid too soon? Mattzilla Civic SI 4 01-12-2007 06:26 PM
Transmission fluid change results ADewan Mechanical Problems & Technical Chat 0 12-04-2006 09:23 PM
First oil change/trans fluid change BEFORE 3500 miles? djdefcon Civic SI 7 08-22-2006 08:36 AM
