My coolant reservoir went empty the other day because the hose running from the radiator pressure cap came off...not sure how. anyway, my question is, if I put the hose back on and just refilled the reservoir, is that going to cause air bubbles to build up? and what possible problems would I have to deal with. Will I need to flush my coolant system to get rid of the bubble.
08 HRP FA5
It should work fine with the small amount you are adding.
Prestone All makes all models is basically a Dexclone. Honda Long Life is basically a Dexclone with phosphates to help with corrosion. If you had to put a lot in, I would just get the HG Honda Long Life stuff. But only filling the puke tank you will be fine. Mine was just a little below the low mark, and I just added some distilled water to bring it up about 1/2 way between the marks. It only took about 8 oz. to do this. Brian |
| Engine coolant/ Motor Oil | RomesKdUB | Forced Induction And Nitrous | 39 | 04-26-2007 04:32 PM |
| What coolant should i use... | lou10788 | Mechanical Problems & Technical Chat | 7 | 11-07-2006 04:37 PM |
| Coolant Leak | untouchablesi | Civic SI | 1 | 10-06-2006 04:23 PM |
| My Si is using coolant | michaelbgone | Mechanical Problems & Technical Chat | 0 | 10-03-2006 09:56 PM |
| How to install heat shield intake gasket and bypass TB coolant on 06 si. | 06redsi | Civic SI | 30 | 08-16-2006 11:20 PM |
