Old 03-15-2007, 05:51 PM   #1 (permalink)
Cablelawyer's Avatar
Jeff Jacobs
Blip on the Dyno Chart
I did some dyno pulls with my 06 Civic Si yesterday. The graph for the first pull looks fine. But every pull after that produced a "V" shaped dip in hp and torque with the downward trend starting just before 6600 rpm and rising again at 6800. Did not hear any engine ping, but according to the dyno the car was definitely cutting back power temporarily and then coming right back to 100%. Has anyone else seen this on their dyno charts?
PDF attached. (The first chart is my Si vs a `07 Cooper S - turbo - note the Cooper S was tested in 20 degree cooler temps). The second chart is my first pull with the Si vs the third pull which was performed after a cool down period of about 10-15 minutes).
Jeff J.
Cablelawyer is offline   Reply With Quote
Old 03-15-2007, 06:02 PM   #2 (permalink)
uhh... "V" tec? lol... i dunno ~.~
taejinah is offline   Reply With Quote
Old 03-15-2007, 06:12 PM   #3 (permalink)
mfinlay04's Avatar
Matt Finlay
Weird sh!t man!! That's def not the vtec cross over as you can see that's happening before the "V" dip. Did they monitor the A/F ratio? would be interesting to see what is happening during that drop
mfinlay04 is offline   Reply With Quote
Old 03-16-2007, 12:45 AM   #4 (permalink)
jdecker's Avatar
james
I am not sure but, on every dyno I've seen with a vtec equipped honda, I noticed a sharp dip right before it engaged. Isn't it the cam switching to the different lobes?
jdecker is offline   Reply With Quote
Dyno top speed video - electronically limited and 9700 rpm NiD4SPD Civic SI 90 10-18-2007 01:06 PM
dyno without the dyno TJ213 Garage 11 03-06-2007 11:32 AM
RANT - Asking for dyno graphs [IVI] Water Cooler 3 01-24-2007 11:28 PM
Stage 6 Dyno Day (56K BEWARE) fuller083 Civic SI 17 01-16-2007 01:05 AM
Honda/Acura Dyno Shootout / Car Meet: March 11, 2006 jasonandre Mid-Atlantic 3 03-11-2006 10:39 PM
