Old 03-14-2007, 10:58 PM   #1 (permalink)
adoBoy619's Avatar
Rollin
CEL with Skunk2 Mega Power
I just put a Skunk2 Mega Power R on my 07 Si today... to go along with my Injen CAI that i've had for about a month. I got a CEL. I checked the bolts to make sure they were tight. But the light stayed on. Im not sure though how tight I should make the bolts (which i think is the most likely problem)...I hand tighened them but i dont want them to break....how tight have you others made the bolts? Also, wouldnt I pretty much know if there was a leak? I probably wouldnt get no real power...right? Or is this engine light normal for the first few days or so? I had the bad smell in my car and it went away after about an hour drive and a bad headache...but thats taken care of...soooo...any thoughts?
adoBoy619 is offline   Reply With Quote
Old 03-14-2007, 11:02 PM   #2 (permalink)
cappykd's Avatar
Kirk
You may have damaged the O2 sensor upon install. DId you just put the exhaust on or a header or test pipe or high flow cat? I just install it on saturday and no check engine light..
cappykd is offline   Reply With Quote
Old 03-14-2007, 11:05 PM   #3 (permalink)
adoBoy619's Avatar
Rollin
All i have is the Injen and Catback. I didnt hit anything except the cat bolts...pretty damn hard too. could that process shook something up?
Old 03-14-2007, 11:21 PM   #4 (permalink)
cappykd's Avatar
Kirk
Yes the CAT could have moved and banged one of the sensors??
Old 03-14-2007, 11:26 PM   #5 (permalink)
adoBoy619's Avatar
Rollin
alright..i'll go to autozone tomorrow during luchbreak..thanks for the help... i'll let you know what happened...anything on how tight to make the bolts?
Old 03-14-2007, 11:29 PM   #6 (permalink)
jay3151's Avatar
Juan Carlos
sounds like u have a bad leak have some one sit in the car and rev it while u look underneath during a cold start u might be able to see some smoke escape. id check that before anything though. maybe the leak is causing the the o2 sensor act a lil crazy giving false reading and so throwin a cell
jay3151 is offline   Reply With Quote
Old 03-14-2007, 11:30 PM   #7 (permalink)
jay3151's Avatar
Juan Carlos
when i did my catbolts i thought i had it tight but it turned out that it wasnt tightend so well i brought it to a shop we lifted it and lightly tightend them. but not sure on how tight they should be.
Old 03-14-2007, 11:36 PM   #8 (permalink)
adoBoy619's Avatar
Rollin
wouldnt i lose back pressure if there was a leak though...my friend had a crack somewhere on his exhaust and the result was his car moving slow as hell
Old 03-15-2007, 12:00 AM   #9 (permalink)
jay3151's Avatar
Juan Carlos
maybe maybe not depending how bad ur leak is.
Old 03-15-2007, 12:04 AM   #10 (permalink)
adoBoy619's Avatar
Rollin
ok..i get what youre saying...imma check it out for leaks tomorrow...i might try and spray some soap and water on the connections and see if they bubble...if so...BAMM...gotta tighten some more
Old 03-16-2007, 06:00 PM   #11 (permalink)
adoBoy619's Avatar
Rollin
went to auto zone yesterday...02 sensor 1 is the problem...now question is...should i change it with another one or use a defouler? i was told by somebody else just to unhook the negative side of the battery for 15 minutes and run it idle after i hook it back up...and it go on but go out after a few mintues in idle...sound about right?
Old 03-19-2007, 09:05 PM   #12 (permalink)
adoBoy619's Avatar
Rollin
just got back from honda about the third gear problem... they decided to check out my O2 sensor. Looks like they are gonna cover that under warranty. Nice Guys
2006+ Si Coupe - Skunk2 Mega Power R - 70MM CatBack Exhaust CorSport CorSport 142 11-30-2008 11:46 PM
2006+ Si Coupe - Skunk2 Mega Power - 60MM CatBack Exhaust CorSport CorSport 83 09-08-2008 07:59 PM
Comptech or Skunk 2 Mega Power R?? Tomoyuki Bolt-Ons And All-Motor 13 03-22-2007 02:05 AM
Where can I get Skunk2 Mega Catback and Fujita SRI???? 06SI_HI Bolt-Ons And All-Motor 4 01-23-2007 02:38 PM
