Old 03-13-2007, 11:21 AM   #1 (permalink)
Streethonda06's Avatar
Greg
High Beams will not flicker(flash)
Okay when the head lights are on i can push the headlight controller forward and my High beams will turn on and stay on... when i pull it twords me its supose to flash my high beams... well it does not... All i have are HIDs hard wired into the factory low beam harness... nothing els is wired up to the factory Lighing system.... does anyone have a sugjestions.....
thank you in-advance
Streethonda06 is offline
Old 03-16-2007, 04:03 AM   #2 (permalink)
check ur fuses and bulbs coz the high beams are dual filament bulbs and even if they stay on and not flciker the bulbs can be bad!
ken42o is offline
High Beams not level? fiji06si13 Lighting, H.I.D.'s, & Neon 22 05-12-2008 06:22 PM
*INSTALLED* High flow Cat on 06 Si dannyboy's06Si Bolt-Ons And All-Motor 7 03-15-2007 06:53 PM
Honk my horn High beams come on! fiji06si13 Mechanical Problems & Technical Chat 43 03-13-2007 11:01 AM
Yellow Beams USDM-FG2 Lighting, H.I.D.'s, & Neon 0 02-22-2007 07:52 PM
Foglight & High Beams wiring kicker_jace Lighting, H.I.D.'s, & Neon 6 06-07-2006 11:52 PM
