hondata reflash problem!!!! - 8th Generation Honda Civic Forum
Old 03-12-2007, 08:35 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
1stk20z3's Avatar
Casey
hey my friend has an 07 Si sedan and got the hondata reflash about 2 weeks ago and it was working fine, it was pretty animal considering the car was stock! it worked well for about a week then he said his cruise control didnt work then he said is stereo went all nuts so he took it to the dealer and told them he got the hondata reflash,so they removed his ECU and replaced with another one and it everything worked fine! to my suprise the gave hime a new ECU but now he just lost a crap load of money! im in the prosses of saving up to get the reflash as well but now im not so sure any advice for me and my friend! and some feedback from people withe the hondata reflash would be a world of good thanks!!!!
1stk20z3 is offline
Old 03-12-2007, 10:40 PM   #2 (permalink)
TJ213's Avatar
that shouldn't cause all those problems, but Hondata REQUIRES an intake or header or exhaust for the reflash
maybe the ECU got messed up during shipping
Old 03-12-2007, 10:42 PM   #3 (permalink)
MutantCheese's Avatar
2008 NFR S2000
Subscribed...waiting for resolution
MutantCheese is offline   Reply With Quote
Old 03-13-2007, 10:08 AM   #4 (permalink)
NIGHTHAWKSI's Avatar
Ian
an intake header or exhaust would not be causing his radio and cruise control to malfunction.
sounds like he should get his money back from hondata.
Old 03-13-2007, 10:14 AM   #5 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
Where is the original ECU that was reflashed by Hondata?
Old 03-13-2007, 10:17 AM   #6 (permalink)
Scrodums
You're going to have to find a way to get that ECU back or something. I think Hondata will need it back to either reflash it or reimburse you.
Old 03-13-2007, 10:24 AM   #7 (permalink)
Werkt06Si's Avatar
Alex
check your ground wires.....that WILLL do it...trust me its happened to me before.
Just make sure that the ground wire thats taped up with the fuel rail wires is grounded to the valve cover...or...intake manifold.
If im wrong or its not the case...then he just got a bad egg out of the nest
Werkt06Si is offline   Reply With Quote
Old 03-13-2007, 10:25 AM   #8 (permalink)
Vince's Avatar
Stephen "Vince" Carter
Sounds pretty fortunate that he got the ECU replaced...I'd have thought that in the situation you described any dealer would say your SOL or charge you full price for a new ECU.
Vince is offline   Reply With Quote
Old 03-13-2007, 11:26 AM   #9 (permalink)
I'm curious about the OP's "animal" comment on the reflash when it was working: I had thought the mid-range loss that Hondata claims after reflash on a stock Si would be significant enough to make the mod not worthwhile when stock (at least that's how I read it on the Hondata website). I realize that regardless of being stock, the raised rev limiter would be worth some kind of performance gain, but how much, really? Is there a dyno of a stock Si with reflash floating around somewhere?
jappchae is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/31889-hondata-reflash-problem.html
considerin hondata...questions - 8th Generation Honda Civic Forum This thread Refback 01-19-2008 01:39 AM
Hondata reflash review - 8th Generation Honda Civic Forum This thread Refback 12-21-2007 12:16 PM
33whp and 30wtq from hondata reflash and DCRH!! 06redsi Civic SI 165 03-28-2009 01:21 AM
Hondata Reflash Question SoFLACiViCSi06 Bolt-Ons And All-Motor 29 04-06-2007 02:13 PM
HONDATA REFLASH!! 06RALLYREDSI Bolt-Ons And All-Motor 69 12-21-2006 02:02 AM
hondata reflash ohnoitzrobbee ECU Tuning Information 27 08-24-2006 05:49 AM
Hondata Reflash Tim CorSport 14 07-26-2006 11:29 PM
