Old 03-08-2007, 12:20 AM   #1 (permalink)
Ahhh! Domokun!
Ruthless909's Avatar
4dr WhOrE!!!
K&n SRI problem
Ever since I installed the SRI my pedals vibrate like crazy, when im on the gas and slowing down....
Ruthless909 is offline   Reply With Quote
Old 03-08-2007, 01:00 AM   #2 (permalink)
Ahhh! Domokun!
4dr WhOrE!!!
15 views and no replys??
Old 03-08-2007, 01:07 AM   #3 (permalink)
Non-FG*Squad_Member 37
ominous8204's Avatar
Chris - Mmmm, VTEC!!!
R18 K&N SRI here...no vibrations...check and double check your bolts. Make sure the brace connected to the heatshield is secure.
I'm getting a CEL though from mine...no limp mode, just a CEL. Problem here is I can't find a place that can read the new Civic's, and I don't want to take it to Honda because they say it'll void my warranty if the see the CEL.
EDIT: I can't really figure our why your pedals would be vibrating though....
ominous8204 is offline   Reply With Quote
Old 03-08-2007, 01:18 AM   #4 (permalink)
Ahhh! Domokun!
4dr WhOrE!!!
Ive double checked every single bolt... The only thing I can think of is the mounting brackets not having rubber washers.
Old 03-08-2007, 01:23 AM   #5 (permalink)
Yea, my mounting bracket to the heatshield has a gigantic thick rubber washer under it. But I still can't figure out how that would cause your pedals to vibrate.
Old 03-08-2007, 06:36 AM   #6 (permalink)
Lobos8403's Avatar
David
Go to home depot.. go to plumbing... go to sink hardware. You'll find some rubber washers.. Cut them to fit. Put one under the bracket and another over the braket then bolt it down. It helped alot for me. Also make sure the heatshield isnt hitting anything. I adjusted the headshield location and that also made a pretty noticable differance.
Lobos8403 is offline   Reply With Quote
Old 03-08-2007, 09:50 AM   #7 (permalink)
Ahhh! Domokun!
4dr WhOrE!!!
So you had the same problem with the pedals vibrating?? Did using the rubber washers completely stop the annoying vibration or just some what...... thanks
Old 03-08-2007, 09:54 AM   #8 (permalink)
Ahhh! Domokun!
4dr WhOrE!!!
Lobos8403 did you use rubber washers for both of the brackets or just one of them.
Old 03-08-2007, 10:57 AM   #9 (permalink)
NIGHTHAWKSI's Avatar
Ian
any place the intake is bolted to the engine, use rubber washers.
i am suprised your kit didnt come with them for the install.....
Old 03-08-2007, 06:49 PM   #10 (permalink)
si4fun's Avatar
have had my K&N SRI on the K20 for about 2 weeks now and have no problems to report of. install went fairly easy and the end result is great!
si4fun is offline   Reply With Quote
Old 03-08-2007, 06:56 PM   #11 (permalink)
sikassdrummer's Avatar
Chris
no vibration or cel here semd me a pic of your set up and ill tell you what the problem is .There is a recall on the accelerator pedal /loose bolts on the pedal mabyee .
sikassdrummer is offline   Reply With Quote
Old 03-08-2007, 08:02 PM   #12 (permalink)
try unhooking your battery for 10 min and then power it back on. I had this problem on my old celica where cause the engine was running lean because it wasn't detecting the proper amount of o2 after a sri install therefore the engine sputtered. resetting the ecu seemed to help. i'm not sure if it works the same way with the new civics but its easy to do and worth a try.
astroboy is offline   Reply With Quote
Old 03-08-2007, 09:02 PM   #13 (permalink)
Lobos8403's Avatar
David
I have an si so i used them on both mounts.. the rear mount was a little tricky to get the washer into so i cut out about 1/6 of it to just slide it in sideways. I slit the washers just so they would fit the bolts a little better. It helps the vibration but it doesnt go away completely... i think? To be honest i got tottally used to it. Really bugged me out for like a day or two then i forgot about it.
Old 03-09-2007, 05:38 AM   #14 (permalink)
Ahhh! Domokun!
4dr WhOrE!!!
cool, I'm gonna have to try that....
R18 K&N SRI CEL ominous8204 Mechanical Problems & Technical Chat 17 06-07-2007 07:39 PM
K&N AND AEM SRI INTAKES LEGAL? lightlypurified Civic Coupe And Sedan 4 01-06-2007 01:03 PM
Injen SRI vs. K&N Typhoon Redleg06Si Civic SI 16 10-05-2006 07:26 PM
AEM Filter on K&N SRI? cirrith Bolt-Ons And All-Motor 5 06-20-2006 04:37 PM
