Old 03-07-2007, 06:50 PM   #1 (permalink)
iVTECpower's Avatar
Ben
Piston-valve contact?
I was coming off of base onto the highway that connects our town to the AFB and I was talking on my phone (stupid) and I downshifted to pass from 5th to 2nd instead of 4th. I was going about 65 or so I think. Could I have possibly caused piston-valve contact. The tach was pinned at 9k, I'm not stupid so I hit the clutch immediately but it had already slowed the car some. I'm such a great driver I thought this would never happen to me. I should not have been talking on my phone and trying to shift with my left hand . I'm extremely disappointed in myself so don't flame me plz
iVTECpower is offline   Reply With Quote
Old 03-07-2007, 07:17 PM   #2 (permalink)
razer's Avatar
your not alone, i did the same thing while talking on my phone but i caught it at 6000 rpm
razer is offline   Reply With Quote
Old 03-07-2007, 07:21 PM   #3 (permalink)
UncleSid's Avatar
Sid
if it only revved to 9k and ur engine didnt explode and no CEL i think you should be fine...
usually if im goin 65 and wanna pass someone hardcore i downshift to 3rd...and thats not too far from 2nd.
UncleSid is offline   Reply With Quote
Old 03-07-2007, 07:31 PM   #4 (permalink)
xlur8ed's Avatar
How does the car run? Idle? CEL? Leaking oil? Did it die when it pegged 9k?
If it runs and drives normal, I wouldn't worry. If any of the above are present, then I would be very concerned
xlur8ed is offline   Reply With Quote
Old 03-08-2007, 02:23 PM   #5 (permalink)
Kidekat's Avatar
The only way you get piston to valve contact is if your timing chain snaps allowing the two assemblies to rotate freely. Or if the gear skips a few tooths.
Kidekat is offline   Reply With Quote
Old 03-08-2007, 02:52 PM   #6 (permalink)
cappykd's Avatar
Kirk
WRONG! The K20 will have piston to valve contact from excessive over revving.
cappykd is offline   Reply With Quote
Old 03-08-2007, 03:18 PM   #7 (permalink)
udumkid's Avatar
Rene....
"valvefloat"
udumkid is offline   Reply With Quote
Old 03-08-2007, 04:32 PM   #8 (permalink)
KShirza1's Avatar
that can cause the head grenade... that sort of contact is very common in a over rev situation and not just in k-series. ive done ot before. take off your valve cover and check you cams and rocker arm assembly. this seriouse, so get checked out.
KShirza1 is offline   Reply With Quote
Old 03-08-2007, 05:20 PM   #9 (permalink)
kamikaze84's Avatar
Blaine
thats what a rev limiter is for.
kamikaze84 is offline   Reply With Quote
Old 03-08-2007, 05:28 PM   #10 (permalink)
06blaksi's Avatar
Rev limiter doesn't work on a mis-shift....as long as it was under 10k you should be ok
Old 03-08-2007, 05:37 PM   #11 (permalink)
cappykd's Avatar
Kirk
The rev limiter will NOT protect against a missed shift over rev, it only helps prevent over rev when shifting at the redline..
Old 03-08-2007, 05:52 PM   #12 (permalink)
rmfa's Avatar
Ronnie
You would know immediately if you were going to have a problem.
Old 03-08-2007, 10:05 PM   #13 (permalink)
SWiFTA06Si's Avatar
ive had the same thing, and when i brought my car in for an oil change they noticed some dirty oil marks right underneath where the cam sensors are, the leak isnt noticable by watching it in idle but i cleaned it a few times and when i checked it there was more oil... Has anyone had to deal with this and figure out the problem....
SWiFTA06Si is offline   Reply With Quote
Old 03-08-2007, 10:20 PM   #14 (permalink)
fyreant's Avatar
ANT
^^you shouldnt have to worry about it.. the dealership should......
fyreant is offline   Reply With Quote
Old 03-09-2007, 12:05 AM   #15 (permalink)
radiocontrolhead's Avatar
Danny
I must have read this same problem on here 4 times from different users. Search works wonders.
Old 03-09-2007, 12:18 AM   #16 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
Werd
Old 03-25-2007, 02:12 PM   #17 (permalink)
WOOCHOW's Avatar
you're fine. go right ahead and keep yapping on your stupid phone, loser
WOOCHOW is offline   Reply With Quote
Fumoto oil drain valve? Fixer Do It Yourself Articles 30 09-26-2007 07:59 AM
Valve Cover R18 Honda in Red disfilam04 Inside and Out 12 08-23-2007 02:14 AM
Canister vent shut valve lammiepie615 Mechanical Problems & Technical Chat 1 02-26-2007 12:09 PM
06 Civic Cold Air Intake With Bypass Valve??? Way2Short Bolt-Ons And All-Motor 7 08-24-2006 04:40 PM
Air Bypass Valve for CAI?? youchasedafterme Bolt-Ons And All-Motor 2 06-25-2006 08:22 PM
