Hidy Ho Neighbor
Pothole - Ouch
I saw the pothole at the last second coming over a rise, and couldn't get around it in time. I caught my right-front wheel. When I finally got out to look at it, I saw that the sidewall of the tire (21540Z18) had a bulge in it. I brought it to the dealer, and they replaced the rubber. Driving home I noticed that when I apply the throttle it pulls to the right. When I'm coasting though, it tracks along fine.
I'll have it bring it in again (obviously) to have this corrected, but can anyone guess (in the meantime) why it pulls right when I give it gas? Thanks. |
#4 (permalink) | |
![]() Join Date: Jan 2007
Rickeh Rickybish Rockymod
#5 (permalink) | |
Phantom Poster
![]() Join Date: May 2006
Justin aka Mr. JT
I sell alingments to all my customers with tire bubbles it's a second nature to do so. Plus it's good money pays 1.8hrs LOL! |
#6 (permalink) | |
Hidy Ho Neighbor
#8 (permalink) | |
#10 (permalink) | |
Phantom Poster
Justin aka Mr. JT
2.or does it gradually go to the right? 1. Is normal 2. Is not it needs an alignment. |
#11 (permalink) |
You may have just knocked the alignment out of spec. UNless the rim was damaged as well.
I don't think Torque steer is correctable by an alignment :) Most FWD vehicles have torque steer, unless you have a LSD. My Old 97 GST spyder had crazy torque steer when all 300HP is applied to the front in 1st -> 3rd gear. |
#12 (permalink) |
You car would have torque steer before and after the pothole.
There are other parts you can damage in the front end other than tires and rims. There are all sorts of parts that can get slightly bent and cause pulling to one side or another. The only odd issue is that it only does it when you apply gas which normally points to torque steer but again you would have it before and after. Was there much difference in tread between the new tire and one that got damaged? How many miles on the car/tire that got replaced?? |
#13 (permalink) | |
Phantom Poster
Justin aka Mr. JT
#14 (permalink) |
Hidy Ho Neighbor
The rim was not damaged. I'll switch the front and back tires. If the problem goes away, I'll have to buy another new tire for the other side. Otherwise, if it still pulls to the right when I hit the gas, then something else is wrong (alignment, or whatever).
Since there are many of you who also have an Si... Does your's pull to the right only when you hit the gas? |
| Ouch!! He's out! | 2fast4u2 | Water Cooler | 10 | 10-10-2007 05:24 PM |
| Pothole experiences ... need some reassurance | eieiou22 | Civic SI | 5 | 02-27-2007 01:22 PM |
| Noise, Ouch | basmoq | I.C.E., Electrical, Security, & Navigation | 6 | 06-07-2006 03:27 PM |
