Belt tensioner pivot bolt HELP!!!!!!!! - 8th Generation Honda Civic Forum
Old 02-02-2013, 01:39 AM   #1 (permalink)
I CAN'T get the bottom bolt on the belt tensioner off for the life of me!!!! PLEASE HELP. It has to come off with an 8 mm Allen wrench, I have everything off except for this one bolt. I've tried to use all kinds of things for leverage!!! Somebody who has successfully done this please help!!!!!! I'm not taking off the mount and dropping the engine to get it off either...
Trav is offline
Old 02-02-2013, 07:55 AM   #2 (permalink)
When I did mine, I removed the tensioner itself to get to that bolt.. (assuming we are talking about the same bolt)
need-for-speed is offline   Reply With Quote Quick reply to this message
Old 03-01-2014, 11:43 PM   #3 (permalink)
this is easy..The pwer steering line hinders the pivot bolt, for easy access of the pivot bolt just open the clip holding the power steering line onto the chassis and removed the two small bolts below the line. your working space should be the alternator area. Use a rachet, an extension and a sawed off 8mm allen.
carfanatic is offline   Reply With Quote Quick reply to this message
Old 03-18-2014, 07:15 PM   #4 (permalink)
I'm sure you've found a way. Share. But if you could already reach it you could use wrench for leverage. Also using smaller ratchets makes thing easier.
Gnay_Kered is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
Product Update/ TSB 09-007: Drive Belt Auto-Tensioner Pivot Bolt Replacement The Power of Dreams Mechanical Problems & Technical Chat 28 12-02-2011 03:25 PM
Question about TSB 09-007: Drive Belt Auto-Tensioner Pivot Bolt Replacement twee202 Mechanical Problems & Technical Chat 4 01-07-2011 01:19 AM
auto tensioner pivot bolt broke help! razorbutt Mechanical Problems & Technical Chat 1 07-04-2010 09:14 PM
Tensioner Pivot Bolt recall went wrong WrongWay Mechanical Problems & Technical Chat 15 04-06-2010 08:51 PM
Drive Belt Auto-Tensioner Pivot Bolt Juaka45 Mechanical Problems & Technical Chat 0 10-17-2009 08:52 PM
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
