No Start...Intake Explosion
Car 2007 si 118k
The car has been sitting not being used since saturday night. Outdoor temp below freezing. I go out to start the car this morning and it wont start. I checked the oil and the coolant all is good. Plugs have been changed within the last 12k So i start cranking it again and it still wont start, so i stop then crank it again this time pushing on the accelerator pedal just for *****, and then the intake box literally exploded and blew all the tabs off and the filter out of the engine compartment. This is the first time ive ever seen an intake explode during a no start. Car ran absolutely fine prior to this. Anyone know what it could possibly be? |
Your tailpipe isn't plugged with some snow or anything is it?
Sent from my iPhone using AutoGuide.com Free App |
#8 (permalink) | |
Andrew
Fuel vapors made their way into the intake and where ignited. When I worked at a dealer I saw this a few times with various cars, including a brand new 2006 Acura RL that wasn't even sold yet. You may have an ignition timing problem, or it was just REALLY bad luck... Did your intake mani get ruined? Check your throttle plate to make sure it didn't bend. |
my manifold is fine. its cranking over just fine. the battery is fine. when cranking it does like a little stumble almost like an attempt to start but then goes back to regular cranking with a stumble here and there almost like its trying to start but doesnt.
i just checked all the fuses and verified that the fuel pump was working...which obviously it was because it backfired thru the manifold. **** is mind boggling. ill go check the throttle plate although that would be collateral damage and not the root cause. |
#10 (permalink) |
i was about a half quart low on oil but topped that off, and that shouldnt have stopped it. there still should have been enough oil pressure to run the timing chain tensioner. and even then, generally an engine will start with no oil at all, it just wont run for long at all.
Any more ideas? |
#11 (permalink) |
I checked the tailpipe for a clog immediatley after the backfire... that was my thought exactly but all checked out fine. i even went so far as to but my optical camera up the pipe to visually see. no luck in that area.
#12 (permalink) |
i checked the butterfly on the throttle body....looks fine minus some soot but thats to be expected.
Q: is the butterfly supposed to move when i push it with my finger? This is my first DBW car, im used to B-series, but when i push on it from the top and bottom it will only move about a 16th of an inch either way. i know on b series cable throttle bodies you can move it fully open by hand but are these different? |
#15 (permalink) |
i let the car sit for a couple hours already. do you think the gas if it were flooded would have seeped past the rings already?
Side-note- i just tried to jump it off my v10 work truck and same thing just cranks and minor sputter. no backfire. The only reason i tried that was to see if my CCA were not in line but it checked out. ill unplug the fuse and crank then try again. Its just odd because this issue just popped up out of nowhere. |
| Help! Car won't start after intake install! | Futurepr3 | Intake & Spacer Discussion | 21 | 07-25-2009 02:05 AM |
| Installed injen intake, car won't start | hmooblis | Mechanical Problems & Technical Chat | 22 | 04-05-2008 12:06 AM |
| Tire explosion | tonton | Mechanical Problems & Technical Chat | 35 | 08-15-2007 09:53 AM |
