LinkBack (2) | Thread Tools | Display Modes |
#1 (permalink)
STIG: a tamed race driver
Recalls, TSB's, and Common problems with the 8thgen civic...
Here are some links to common problems associated with the 8thgen civics. If you would like to add something (a recall, TSB or general problem) please post it AND PM me and I will add it to the list. This list is only for problems that seem to be common and just because it does not show here, does not mean there is not a thread about it. So please search if you can't find what you are looking for. If you still do can not find your problem, start a thread, thanks! :)
Recalls http://www.motortrend.com/cars/2006/...lls/index.html gas pedal HERE Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) NHTSA CAMPAIGN ID Number : 05V509000 Mfg's Report Date : NOV 02, 2005 Component: VEHICLE SPEED CONTROL:ACCELERATOR PEDAL Potential Number Of Units Affected : 25298 Front airbag sensor on coupes Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) NHTSA CAMPAIGN ID Number : 05V572000 Mfg's Report Date : DEC 22, 2005 Component: AIR BAGS:FRONTAL Potential Number Of Units Affected : 12756 No amber reflector on headlights Make : HONDA Model : CIVIC Year : 2006 Manufacturer : ANZO USA, INC. NHTSA CAMPAIGN ID Number : 06E023000 Mfg's Report Date : MAR 09, 2006 Component: EXTERIOR LIGHTING:HEADLIGHTS Potential Number Of Units Affected : 97000 TSB - Technical Service Bulletins Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 1205 Date of Bulletin: DEC 16, 2005 NHTSA Item Number: 10018868 Component: POWER TRAIN:MANUAL TRANSMISSION Summary: TRANSMISSION GRINDS AT SHIFTS, SKIP SHIFTING. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 1105 Date of Bulletin: NOV 16, 2005 NHTSA Item Number: 10018257 Component: ELECTRICAL SYSTEM Summary: ACCESSORY POWER SOCKET INOPERATIVE. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018474 Component: ELECTRICAL SYSTEM Summary: NEW SOFTWARE FOR HDS: VERSION 2.001.01. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018477 Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Summary: WHY A PC CARD WONT PLAY IN THE AUDIO UNIT. APPLIES TO '06 CIVIC EX AND SI MODELS WITH THE NAVIGATION SYSTEM. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018479 Component: SEAT BELTS Summary: NEW SEAT BELT REMINDER LOGIC FOR '06 MODELS. APPLIES TO '06 ACCORDS, '06 CIVICS, '06 PILOTS, AND '06 S2000'S. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018480 Component: ELECTRICAL SYSTEM Summary: NEW IMMOBILIZER SYSTEM ON '06 CIVICS. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018482 Component: ELECTRICAL SYSTEM Summary: TAKING THE MYSTERY OUT OF THE MAINTENANCE MINDER SYSTEM. Common Problems Rattle from the rear. Cliff notes: a clip was not installed properly or some wires where loose. Your power somehow gets reset, and the Navigation asks you for a pin and you don't know what to do or it automatically goes blank. Rough idle problems, no solution yet Starting Issue /Ignition issue/ - Merged threads Car takes a few seconds of cranking before starting, let the key set in the "on" position for a second or two helps. A/C condensor protection, a few people have had problems and it costs $700 for the dealer to fix, this costs $10 and an hours of time, see second page There is an engine ticking at idle, I've been told by about five Honda techs that it is the fuel injectors. Also, if you don't see what you are looking for, there is another DIY index in the Tech stuff and DIY section, CLICK HERE Finally, there is also a DIY index for I.C.E. and electrical, so if you don't see what you're looking for here, CLICK HERE Any additional info would be greatly appreciated!!! ![]() Last edited by CameronJr9; 11-23-2007 at 08:40 AM. |
Drivers side door not lining up correctly.
Whenever I look at my drivers side rear view mirrors I notice it and it bothers me. Will be taking it in soon to get fixed. Be careful about the metal panel. Went to get a new Alarm system put in yesterday and without my knowledge the installation guy was hitting the top metal panel right above the drivers side window and it placed a nice dent there. I know it wasnt there when I took it in since It is eye level everytime I get into the car. That pissed me off. Talked to manager already and have to take car in so they can see it. I wouldnt of said anything if that part wasnt so clean when I was going into my vehicle this morning since my car is fairly dirty and that part was the only spot clean. |
#6 (permalink) | |
LED Lights on the Vent Selection buttons all turn off at random. Problem is only solved by hitting the buttons. Though this is a temporary fix cause they go off on the next bump in the road. This is not the only one this dealer has seen and I others on the board have experienced it as well I believe.
#8 (permalink) | |
Crazy Yellow Puppet
Back and Forth Forever
#12 (permalink) |
i used to go to alldata for TSB's but now they charge a fee
this is a substitute i found linked to a .gov url. just search for your car and the known tsb's will come up. http://www-odi.nhtsa.dot.gov Currently has 7 TSB's for an 06 civic. TSB's have helped me out with my chrysler 300m special that was filled with problems. I went to the dealer with a list of the TSB numbers and they knew exactly what to fix, and that is was indeed covered by chrysler. |
#13 (permalink) | |
#14 (permalink) |
TSB's 1-7
Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 1205 Date of Bulletin: DEC 16, 2005 NHTSA Item Number: 10018868 Component: POWER TRAIN:MANUAL TRANSMISSION Summary: TRANSMISSION GRINDS AT SHIFTS, SKIP SHIFTING. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 1105 Date of Bulletin: NOV 16, 2005 NHTSA Item Number: 10018257 Component: ELECTRICAL SYSTEM Summary: ACCESSORY POWER SOCKET INOPERATIVE. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018474 Component: ELECTRICAL SYSTEM Summary: NEW SOFTWARE FOR HDS: VERSION 2.001.01. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018477 Component: EQUIPMENT:ELECTRICAL:RADIO/TAPE DECK/CD ETC. Summary: WHY A PC CARD WONT PLAY IN THE AUDIO UNIT. APPLIES TO '06 CIVIC EX AND SI MODELS WITH THE NAVIGATION SYSTEM. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018479 Component: SEAT BELTS Summary: NEW SEAT BELT REMINDER LOGIC FOR '06 MODELS. APPLIES TO '06 ACCORDS, '06 CIVICS, '06 PILOTS, AND '06 S2000'S. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018480 Component: ELECTRICAL SYSTEM Summary: NEW IMMOBILIZER SYSTEM ON '06 CIVICS. Make : HONDA Model : CIVIC Year : 2006 Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.) Service Bulletin Num : 09012005 Date of Bulletin: SEP 01, 2005 NHTSA Item Number: 10018482 Component: ELECTRICAL SYSTEM Summary: TAKING THE MYSTERY OUT OF THE MAINTENANCE MINDER SYSTEM. |
#16 (permalink) | |
Good source... thanks :) |
#18 (permalink) |
i'm back, light is still on..
conclusion - honda techs there are idiots.. and i wasted an hour and 10 minutes waiting. Can't they see the light came on when they gave me the car back to bring it back in and diagnose it?? IDIOTS
- Mark 2008 Honda Civic SI (stock) 2006 Honda Civic EX (sold) |
