Old 11-07-2006, 10:36 PM   #61 (permalink)
I concur, add me to the list. The fbw could be a little less sensitive in first gear, I'm guessing they changed the code processing the voltage feedback in the SI reflash update.
ndoelling is offline   Reply With Quote
Old 11-09-2006, 07:43 PM   #62 (permalink)
damon300s's Avatar
Damon
Yea I am not sure, But I do know it is way to sensitive......gets on my nerves sometimess!!!!
damon300s is offline   Reply With Quote
Old 11-12-2006, 09:05 PM   #63 (permalink)
articsilber323's Avatar
where can i find all the tsb letters
articsilber323 is offline   Reply With Quote
Old 11-13-2006, 10:45 PM   #64 (permalink)
leonsphinx's Avatar
Angry DBW lag - same problem
Originally Posted by damon300s
Does anyone one think that might be the same problem that the Si's had. I think it is in both the Si and the EX. Heck the LX has the same engine, So problem might be in all Civics.... Let me know who else has this problem....
Yup, same problem here. to give an example: I'm travelling at around 40-50 kph and approach an intersection...i slow down to around 10-15 then step on the gas...takes around 1-2 seconds for the accelerator to respond. i can feel that the engine is like choking...I have a 1.8S A/T Asian model
leonsphinx is offline   Reply With Quote
Old 12-16-2006, 07:03 AM   #65 (permalink)
Dan Mechanical's Avatar
Make : HONDA Model : CIVIC Year : 2006
Manufacturer : HONDA (AMERICAN HONDA MOTOR CO.)
Service Bulletin Num : 09012005
Date of Bulletin: SEP 01, 2005
NHTSA Item Number: 10018479
Component: SEAT BELTS
Summary:
NEW SEAT BELT REMINDER LOGIC FOR '06 MODELS. APPLIES TO '06 ACCORDS, '06 CIVICS, '06 PILOTS, AND '06 S2000'S.
Any details on this? My seatbelt warning starts whining at me as soon as I turn the ignition. I usually get in the car, turn it on, put on seatbelt, close door, and the drive. I don't need the seatbelt reminder screaming at me the whole time for no reason and I'd love to get it fixed.
Dan Mechanical is offline   Reply With Quote
Old 12-16-2006, 10:55 AM   #66 (permalink)
PokeyD16Z's Avatar
thats not a fix...it just tells about the new seat belt reminder logic.
Old 12-16-2006, 02:27 PM   #67 (permalink)
Avenger's Avatar
Rob
What you SHOULD be doing is:
- getting in car
- closing the door
- putting your seatbelt on
- starting the car
- driving away
........you've just got your order mixed up. I'm surprised that people don't even know what order they SHOULD be going in every time they drive.
Avenger is offline   Reply With Quote
Old 12-17-2006, 06:02 PM   #68 (permalink)
- getting in car
- closing the door
- starting the car
- driving away
Why?
Back in the day I was a delivery driver. Its dive into car get it started, do everything else, drive away fast. The engine gets oil flowing through it. You free up one hand from your keys. Old habits die hard. Would the new seatbelt reminder logic fix this or not?
Old 12-19-2006, 12:07 AM   #69 (permalink)
PokeyD16Z's Avatar
Are you talking about the beeping when you start the car? Thats on every car...has been like that for Hondas forever. Thats not the new seatbelt reminder at all...thats the normal startup chimes. The new seatbelt reminder goes on only after you start driving...it won't activate until you move...and the icon will blink, also.
By the way, as I mentioned beofre...there is no new seatbelt logic except for the one that came with your car and every other 2006+ Civic and other Hondas. The TSB is ONLY an informational TSB.
Old 12-19-2006, 08:14 AM   #70 (permalink)
Thanks, PokeyD16Z.
Old 12-27-2006, 03:54 AM   #71 (permalink)
Hanging Revs FIXED!
I have an 06 Civic Si Coupe that I got in March of 06. The car has been great except the complaint that a lot of the car mags had about the "hanging revs." In other words, when you push in the clutch and take your foot off the gas before shifting the revs do NOT fall at all for at least 1-2 seconds. This makes for jerky shiftin and causes clutch wear. Worse, when you are in stop-and-go traffic and go to take your foot off the gas to let the car slow down the car continues to go the same speed even with your foot off the gas pedal due to these hanging revs.
There is a service announcement about this but it is ONLY FOR SI OWNERS WHO COMPLAIN (like me!). They reflashed my ECU and now the revs fall pretty naturally and the off throttle coast is normal, too. It is worth making a bit of noise at your dealership to have it done. It makes the car much smoother and safer to drive, and enhances performance driving at the same time!
e36jakeo is offline   Reply With Quote
Old 12-27-2006, 03:59 AM   #72 (permalink)
drfters13's Avatar
do they charge you for taking it in to get the rev hang fixed
drfters13 is offline   Reply With Quote
Old 12-27-2006, 04:37 AM   #73 (permalink)
No charge -- this is a warrentee issue.
Old 01-12-2007, 11:37 AM   #74 (permalink)
crableg85's Avatar
mikey
i have an 07 should i be weary??
crableg85 is offline   Reply With Quote
Old 01-30-2007, 03:38 PM   #75 (permalink)
Vince's Avatar
Stephen "Vince" Carter
About the rev hanging issue? I have the same problem with my 07 that has supposedly been fixed in 06. I need to call my service dept but I just hate dealing with those retards (dealer service in general).
Vince is offline   Reply With Quote
Old 02-01-2007, 09:31 PM   #76 (permalink)
How about the brakes on the SI? Anyone else have a problem with them when ur going a decent speed and hit the brakes hard. Not so hard that u would skid but hard, and it seems they slip and the pedal doeswnt feel right and u lose alot of braking power.??? its a little scary. It almost seems like if i was to need the brakes in an emergency I would be screwed and get into and accident. =/ Anyone else?
blackSI06 is offline   Reply With Quote
Old 02-02-2007, 10:15 AM   #77 (permalink)
Vince's Avatar
What's the maintenance history of your brake system? Did you buy the car new or used? You could just need a brake job, maybe the fluid is low. How many miles you got on the car?
Old 02-03-2007, 06:04 AM   #78 (permalink)
strCIVIC's Avatar
Starting Issue /Ignition issue/ - Merged threads Car takes a few seconds of cranking before starting, let the key set in the "on" position for a second or two helps
^^^^^^this is true!! when i bought my 2006 honda civic ex coupe auto with only less than 500miles...i had a hard time starting up my car...it happen maybe 4-6times since then...but i have no problem at all now...my car has about 4,880k miles...
strCIVIC is offline   Reply With Quote
Old 02-13-2007, 10:44 AM   #79 (permalink)
CAN ANYONE POST RPM HANGING UP LINK??
THX
hubert is offline   Reply With Quote
Old 03-04-2007, 01:52 PM   #80 (permalink)
mattsbobo's Avatar
Who watches the Watchmen?
Wrong odometer readings
Is the mis-counting odometer just an issue for the hybrid? I've got a 06 Si coupe, and sometimes I think the milage on it isn't right. Is there a fix for this, or are they just doing the 5% extention of your waranty?
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/3117-recalls-tsbs-common-problems-8thgen-civic.html
Honda Civic 2006+ Issues - CarSpace Automotive Forums This thread Refback 02-02-2008 01:23 PM
Honda Civic 2006+ Issues - CarSpace Automotive Forums This thread Refback 01-11-2008 10:47 PM
Toyota Corolla - world's best selling car ever award webby Garage 33 01-08-2008 09:01 PM
how fur coats are made webby Water Cooler 10 07-14-2006 02:41 AM
Local Meets webby Mid-West 7 04-24-2006 09:30 PM
Real Facts 1-109 C2i0v0i1c Water Cooler 8 07-18-2005 10:12 AM
