Old 03-06-2007, 08:56 AM   #1 (permalink)
06blaksi's Avatar
1st gear and Vtec
I had a problem when I was running the stock tires after they were worn. As soon as I hit vtec in first, they would break loose. I attributed this to the tires being bald. I replaced them with the same size Kumho Solus to try and keep the same tread pattern as the rear stockers. Now if I run first up and hit vtec, I get slight wheel-hop as soon as vtec kicks in. Enough to vibrate the inside of the car. I suppose I'll have to get yet another set of tires to fix this.
It's not like I have massive amounts of hp here. Has anyone else had this problem?
Old 03-06-2007, 09:43 AM   #2 (permalink)
stevenshizzle's Avatar
Steven
Not yet, but I reckon a torque damper may help out at VTEC engagement. Tell you the truth, I don't really floor my car in first because I know that my tires may break loose. I should try it more often.
stevenshizzle is offline   Reply With Quote
Old 03-06-2007, 11:10 AM   #3 (permalink)
xmx250's Avatar
No i dont have that problem at all. Actaully i couldnt imagine my tires hopping or breaking loose on VTEC engagement. Wow i wonder if my car is making low power?
xmx250 is offline   Reply With Quote
Old 03-06-2007, 11:12 AM   #4 (permalink)
honda06si's Avatar
justin
have you broke the tires in? i mean you probably already know to do this but maybe you forgot. all new tires have like oil on them or something and they actually get traction like bald tires until they go through like 3 heat cycles
Old 03-06-2007, 11:14 AM   #5 (permalink)
06blaksi's Avatar
They have almost 500 miles on them. I made a short road trip up to Hartford last weekend...60 miles each way. I think that should be enough.
Old 03-06-2007, 11:18 AM   #6 (permalink)
honda06si's Avatar
justin
that sucks man! call kuhmo or something tell them your unsatisfied
Old 03-06-2007, 11:23 AM   #7 (permalink)
xmx250's Avatar
Yeah maybe your tires are bad?
BTW when are you guys going back to the dyno?
Old 03-06-2007, 11:25 AM   #8 (permalink)
06blaksi's Avatar
Jordan is going back in the next week or two...he's getting Hondata...I won't be for a couple months after I get Hondata and possibly an exhaust
Old 03-06-2007, 11:50 AM   #9 (permalink)
drexp2000's Avatar
Do you have a '07 model? If so, turn off VSA...
drexp2000 is offline   Reply With Quote
Old 03-06-2007, 12:12 PM   #10 (permalink)
06blaksi's Avatar
No...2006 with 16k miles on it
Old 03-06-2007, 12:42 PM   #11 (permalink)
60103's Avatar
Ken
happens to me once in a while when the roads really cold, like at night, but during the summer i never had a problem.
60103 is offline   Reply With Quote
Old 03-06-2007, 12:49 PM   #12 (permalink)
baz938's Avatar
^^^yea same for me too^^^, especailly today when its 5 degrees out but they dont break loose too bad
baz938 is offline   Reply With Quote
Old 03-06-2007, 08:50 PM   #13 (permalink)
i was having this exact same problem with my toyo proxes 4. but then i found a solution. i never realized how much tire pressure affects performance til now. when i would spin in first my tire pressure was at 35psi. i dropped it down to 32psi and then put the rear tires at 29psi. now i get no wheel hop, but i sure do get sucked backed in my seat now.
kurdtkobain87 is offline   Reply With Quote
Old 03-06-2007, 09:35 PM   #14 (permalink)
06blaksi's Avatar
Good input! I'll try that in the morning...thanks
Old 03-06-2007, 09:56 PM   #15 (permalink)
Ignorance is Bliss
Qshooter151's Avatar
Jordan
i get it sometimes too. just never really attributed it to anything. i have the summer tires still on the car and it's happened in both warm and cold weather...gonna adjust the pressure tomorrow and see if that helps...
...I'm going back to the dyno on my b-day! Mar 14th 6:00pm
Qshooter151 is offline   Reply With Quote
Old 03-07-2007, 08:41 AM   #16 (permalink)
06blaksi's Avatar
Can't wait to see the new numbers!!!
33whp and 30wtq from hondata reflash and DCRH!! 06redsi Civic SI 140 03-30-2008 01:26 AM
CPU and Vtec questions. tommyroo Mechanical Problems & Technical Chat 8 03-04-2007 06:45 PM
shouldnt i be a lil faster? 06blkstealthsi Autocross & Sanctioned Drag Racing 12 01-25-2007 03:42 PM
I Finally Hit VTEC. Special Ringpop Civic SI 33 09-02-2006 04:38 PM
Wierd Vtec sound 06_civic_si_gi Mechanical Problems & Technical Chat 8 07-20-2006 02:02 AM
