Dealer changed Oil but not filter WTH..
So I went to to the dealer to get my oil changed. They said I was early because it's at 30%. Well anyways I said I want to get it done. Took an hou rand they said they changed oil but not filter because it is not required and told me I'm good till end of year and filter will be changed in next oil change service.
Should I be concerned? If yes then what should I do? Thanks |
Most all modern cars don't need/ require oil filter changes every time. If you car is dirtying up a filter in one oil change then there is much larger issues at play.
I've got 70k on my 2007 civic and I've followed the MM down to zero% and every other oil change I used a good quality filters and what ever brand of synthetic is on sale. |
#10 (permalink) |
good to learn...
wow... this is a shock. who knew $tealers were not changing filter each service.
now i can understand if one changes oil frequently, but after 6000 miles with only 4 qts of oil in engine i believe i will continue filter change w/oil change. |
#11 (permalink) | |
I find it interesting that so many members of an enthusiast forum find it shocking that a dealer would follow the MM, and perform PM exactly as Honda specifies. Last edited by gathermewool; 01-23-2013 at 01:29 AM. |
#13 (permalink) |
Martin
I don't listen to that 15% b.s. I do my oil change every 3000 miles and I use mobile1 and oem filter. DO NOT let the dealer do that to you it's is bull ****. These cars can loose up to a qt of oil every 1000-1500 miles and they want you to go to 7500? Depending on driving styles. I have a buddy that works at Honda and talked to him about it because when I bought my car they told me about that system and I didn't like it from the start so I figured I'd confront him about it and he said the same thing I did, DO NOT let the dealership do that to you. Just my opinion.
Sent from AutoGuide.com App |
#15 (permalink) |
filter only blocks debris and larger particles of soot. If your filter is filtering correctly, it will keep all the crap it collected in the filter medium, not put it in the new oil. It will tinge the oil a darker color yes but that color is soot from combustion that the filter cannot filter as it is too fine a particle.
#16 (permalink) | |
![]() Join Date: Dec 2010
Gary
Wish I could find the thread, had bob the oil guy in it. Anyways, from what I got from it, the filter should always be changed because of exactly the bolded text above. Not to mention the filters tend not to filter as well after extended use. So not only are you leaving all the old contaminates in your oil, but your also not filtering it as well. IMO its worth the piece of mind knowing my engine is as contaminate free as I can get it w/o flushing. less contaminates = less wear Last edited by killswitch21; 01-23-2013 at 02:11 PM. |
#17 (permalink) | |||
Three things: 1. It's Mobil 1 2. 3,000 mile intervals is ridiculous and antiquated, and you have nothing at all to show that the MM-indicated change interval is anything but conservative. You know who does? People who send out samples for analysis. 3. I don't care what kind of car you drive, the oil should be checked occasionally. Consuming oil is only an excuse for those who can't be bothered to maintain their vehicles properly, and a poor one at that. Quote:
It's fine to be driven by how you feel, and it's ok if you'd like to change your oil and filter every 3k miles for PEACE of mind, but, as I always argue, where do you draw the line? A good filter will filter well for two MM-driven OCI's. The used oil remaining in the filter is inconsequential. This is the 21st century, people - get with the times! Last edited by gathermewool; 01-24-2013 at 02:19 AM. |
#18 (permalink) | |
Martin
2.3000 miles is not ridiculous. 3. He has been a auto tech for 7 years. So Im just playing it safe and don't want to trust that kind of system. But you can do what you want lol hope everything works out for you. Sent from AutoGuide.com App |
#20 (permalink) | |
Gary
I know 3k intervals is a thing of the past.. Hell alot of cars suggest 5k in the owners manual now.. Last edited by killswitch21; 01-24-2013 at 09:43 AM. |
| Break in oil? Dealer changed oil for PDI.. | KFRG | Mechanical Problems & Technical Chat | 19 | 03-26-2010 12:28 PM |
| Am I stupid for getting oil changed at dealer? | steelersfan1 | Civic SI | 32 | 08-05-2009 10:28 AM |
| Changed the Cabin Filter and Air filter. | patricklg12 | Civic Coupe And Sedan | 14 | 03-26-2009 01:40 AM |
| Oil changed at the dealer... | Asif22 | Mechanical Problems & Technical Chat | 6 | 06-09-2008 10:08 PM |
| how much oil you put in SI with filter changed | miles10238 | Civic SI | 4 | 09-15-2006 12:52 PM |
