#21 (permalink) | |
![]() It sounds like you're doing the right thing, choosing a conservative interval. I follow the MM because it's easy and conservative (with my oil and filter choice) -- it doesn't require my wife to track anything other than pushing the button and telling me what the percentage is every so often. Even if she forgets to do that, the little wrench will eventually pop up to indicate that a change is coming due. Because this engine is used so gently (my wife rarely gets above 4k RPM and my driving only accounts for maybe 2% of overall mileage,) I've been using just about any decent oil that I find on sale and changing it at 10-15% MM. I am, however, considering running an even better oil, sending out a sample for analysis, and maybe trying to extend my interval out to double that (down to 10-15%, change and reset MM, and then down to 10-15% again on the same oil and filter.) With an oil like M1 EP, PP/PU, or Edge, 12k miles+ should be very easy to attain. I may send out for an UOA anyway, just to share with the community. I installed a Fumoto drain valve on both her Civic and my Subie, so obtaining a sample and topping off when the MM gets down to 15% will be easy to do AND allow for plenty of time to receive the report before I reach my normal have-to-change-the-oil-NOW point on the MM. Unfortunately, I've got Maxlife 5W-20 in there, which I'm only running because it was on sale. For the sake of analysis, I'd like to keep the same oil in there for a few intervals so I can compare the first to the last directly (same chemistry,) and determine whether my extended interval is SAT. Sorry for my digression, but hopefully I can provide some actual data, and if I only sway one person away from their ingrained early-change-interval habit I'll be happy. Regardless, I'm a big 'ol dork, so the data itself will be its reward. My wife rolling her eyes when I try to explain it to her is worth every penny, too! |
#22 (permalink) |
Martin
Dealer changed Oil but not filter WTH..
I just like to keep fresh oil in my car. Hondas are very reliable as long as you change the oil so when my car runs forever lol and yours doesn't than.....
It's really not that much more money. I'd rather protect my investment then take a chance. Sent from AutoGuide.com App |
#23 (permalink) |
Oil is changed Filter ain't. The problem is I went with 30%. If I had gone with 15-10% they probably would have changed the filter. I don't drive much I had 30% on 5500 kms. Yes, I drove 5500 in a year so I guess the filter won't hurt me.
#25 (permalink) | |
Your car is not an investment, either. It's a machine, a tool that depreciates in value and has one sole purpose: to get you where you need to go, as cheaply as possible. I'm also not sure if you've noticed how many older Civics are on the road today. I see a lot that are smoking and dripping oil around my area (probably due to running the oil level low and changing the oil too infrequently,) but they run and they run well. They're also very popular with "tuners," or those who install a fart cannon and rally-x their little POS around town, so these engines are a little more durable than you think. With that being said, fresh oil does not lubricate or clean any better than half-used oil. The oil in your sump either has additives left to disperse and maintain clean your engine, to lubricate and cool your engine, or it doesn't. Changing your oil when it still has 50% or more of its life left buys you nothing but a hole in your wallet, plain and simple. I'll say again that if you choose to change your oil sooner than necessary, you're doing it for you, for your peace of mind, not for the benefit of you motor. So, while I'll suggest against short intervals I won't attack you for doing so. To say that my engine will fail because I follow the MM is absolutely foolish. It is interesting seeing how people react when you shake the foundation for their thinking. The fact that there are STILL people who will fight you tooth and nail over an archaic 3k miles interval is astounding. It's almost as bad as those who not only preach shorter intervals, but also dump into their sumps garbage like Lucas or Motor Honey, as well as those who run 93 octane in their R18. No guessing needed, only 3417 miles on your filter is nothing! Last edited by gathermewool; 01-24-2013 at 11:50 PM. |
#26 (permalink) |
Roe R18 Crew Member# 1980
Check this out: thecarconnection.com Changing Your Oil Too Often? You Might Be Surprised
And this one: http://www.skepticblog.org/2009/02/22/oilchange-rant/ Info about oil: http://www.valvoline.com/car-care/motor-oil-myths/ http://www.topspeedracer.com/synthet...gular-oil.html Last edited by roe956; 01-25-2013 at 12:22 AM. |
#27 (permalink) | |
#28 (permalink) | |
Your auto tech buddy with 7 years of wrench experience is nothing compared to the engineer with 7 years of college and decades of testing oil in a million dollar lab. Plus these engineers in over 20 engine makers have all come to trust the science and all have long oil life standards..... |
#29 (permalink) | |
Martin
#30 (permalink) |
Just to clarify, there is NO MM for with or without a new oil filter. HONDA says change oil and filter together every 12.5k. I only speak the truth and always have proof to back up what i say. you want proof here it is in black and white.
Maintenance Schedule for Normal Conditions - European Model |
#32 (permalink) | |
http://techinfo.honda.com/rjanisis/p.../ACV0808OM.pdf MAIN ITEM A Factory Recommended Maintenance Replace engine oil.* MAIN ITEM B/B1 Factory Recommended Maintenance Replace engine oil* and filter. Service front and rear brakes. Check parking brake adjustments. Rotate tires**, inspect for wear and adjust pressure. Inspect tie rod ends, steering gear box and boots. Inspect suspension components. Inspect driveshaft boots. Inspect brake hoses and lines (including ABS). Check all fluid levels and condition of fluids. Inspect exhaust system. Inspect fuel lines and connections. Last edited by gathermewool; 01-26-2013 at 12:58 AM. |
#33 (permalink) | |
8000 miles on oil in US. With oil filter every 16,000. Tells me oil is good for at least the 8000 miles or so when my MM is zero. Such oil in Europe would still have 4500 miles of life. My guess is the European oil filter must be changed at 12,500 because 25,000 would be way too long of an interval. Both American and Eurpean models show that the oil and filter can last many many miles...
#35 (permalink) |
Just so you know the MM system in the car does not know the actual condition of your oil, it uses a pre set calibration that uses the way you drive to attempt to determine when your oil must be changed. i usually go thru 2 MM before changing as my oil still looks like the day i put it in on the first MM, and i have 120k on my si.
#36 (permalink) | |
Welcome to the conversation...
#37 (permalink) | |
Before i get the question would i wait 10k miles to change oil, hell no i wouldnt simply bc we have VTEC motor that requires oil pressure, coolant to engange vtec. But if it was a econo car that took 0w20 oil i would bc 0w20 is sythentic oil. But i see other ppl linked that its fact that 3k miles is wasting oil
#38 (permalink) | |
Martin
| Break in oil? Dealer changed oil for PDI.. | KFRG | Mechanical Problems & Technical Chat | 19 | 03-26-2010 12:28 PM |
| Am I stupid for getting oil changed at dealer? | steelersfan1 | Civic SI | 32 | 08-05-2009 10:28 AM |
| Changed the Cabin Filter and Air filter. | patricklg12 | Civic Coupe And Sedan | 14 | 03-26-2009 01:40 AM |
| Oil changed at the dealer... | Asif22 | Mechanical Problems & Technical Chat | 6 | 06-09-2008 10:08 PM |
| how much oil you put in SI with filter changed | miles10238 | Civic SI | 4 | 09-15-2006 12:52 PM |
