Ian
For Those With Doors That Close VERY Easy...
Here is the fix:
Buy new door checks. The part numbers are the same from 2007-2011. Just order new ones, and replace the old ones. It completely fixes the issue of the doors closing too easy. I just wanted to post this up, as there have been a number of different threads discussing this, but no answers regarding what would fix it. |
#4 (permalink) | |
Ian
Yes. Remove the door panel, pull back the dust cover, and unbolt the current check. Remove it, put the new one in, bolt it in place, and put the door back together. It's an easy fix. It just took me a couple hours cause I had never removed the door panel before, and wanted to be careful. |
#9 (permalink) | |
Rich
Kind of what I figured and thanks.
#10 (permalink) |
im not sure how this happened i guess i was on a slope but the door came swinging back and clocking me in the face. ive also slammed my leg because the door came flying back trying to close. i kinda feels like itll stay open but as soon as u let your guard down BAM! here comes the door. its almost like the mechanism that would hold the door open just gives out randomly might be just plain weak or worn out. imma have to try this.
#11 (permalink) | |
Ian
__________ Parts Used: Ratchet, 10mm socket, 12mm socket, 6 inch extension __________ OK, so I did my passenger side one tonight. It went MUCH quicker since I knew how the door panel came off, and to unhook everything, etc. I would say an hour, tops, from start to finish. So here is a pic of the door panel off. You will peel back the dust cover starting at the top left corner, as much as you can. I then taped it out of the way, as whatever adhesive they use makes a damn mess if you get it on anything (I recommend wearing a pair of nitrile gloves when you do this for that reason alone). One the dust cover is taped out of the way, you will undo the three bolts in the second picture. Take the old door check out, and put the new one in. NOTE: depending on how you receive the door check, you may have to get creative. the one on the driver side was in the "closed" position, and so I had to muscle it in to the first recess in order to install it. After you have the new door check in place, I put the two bolts that are on the door in first, and then you will probably have to close the door a bit to get the check to a place where you can bolt the door check to the chassis. After you have these three bolts in (and they don't need to be 100% tight), go ahead and open the door fully, and you can tighten down the bolts the rest of the way. Then, just put the dust cover back in place, put the door panel back on, and button it up. Waalaa, no more door closing on your face/fingers/legs. ![]() ![]() I will say that the trickiest part is getting the lock mechanism cables off/on. Just pay attention to how they come off, and you'll be good to go putting them back on. This was the biggest time consumer when I did the driver side door, but since I knew what to do the passenger side was a breeze. |
#13 (permalink) |
Ian
They're like, $12.50 or so from Autofair Honda. But unless you are going to buy other things as well, the shipping makes it pointless.
If all you need is the door check, you're better off going to your local Honda garage (I suggest calling to order it, as they will likely not have this in stock). |
#14 (permalink) |
Jay
So glad I found this. I open my door, reach over to the passenger seat to pick up my work jacket and by the time I turn around to get out of the car the door is already about to smash me in the face. Definitely putting this on my to-do list! Thanks!
#15 (permalink) | |
Ian
I can guarantee you that this will fix that issue. It's a cheap and easy fix! |
#17 (permalink) | |
Ian
And my new door checks hold very well at the notches too. It's just because they are new is all. Like I said earlier, even if I have to do this every 4 years it would still be worth the $25 in parts and the couple of hours of work involved. Bottom line, new door checks will fix this issue. |
#19 (permalink) |
Ian
The checks come pre-greased from the factory. I would only grease them if you notice a LOT of resistance (like the door is difficult to close).
And yes, white lithium grease would be a good grease to use if they ever need greased. |
#20 (permalink) |
Ed
I changed mine a couple of days ago. WOW, door opens/closes like a new car! When you open it, the door actually stays open!! Something I've forgotten all together. Anyway, cheap, easy to do. But yeah, I wonder how long this will last. As the OP states, it's so inexpensive, who cares.
| My doors close EXTREMELY easy, help? | ijm5012 | Inside and Out | 42 | 05-31-2012 09:36 PM |
| Intake question between the 2 doors and 4 doors? | gixxerspeedfreack | Garage | 9 | 05-31-2012 01:45 AM |
| Quick fix for hard-to-close doors/boot (pics) | chylld | Mechanical Problems & Technical Chat | 4 | 09-15-2006 12:53 AM |
| Why are the doors so hard to close ?? | jayjr98 | Mechanical Problems & Technical Chat | 5 | 04-24-2006 05:33 AM |
