Old 03-03-2007, 04:51 PM   #1 (permalink)
Car starts and dies
So I installed the AJP manifold, high flow cat and 3" exhaust. I have an Injen SRI and while all this was going on i had my ecu reflashed by hondata. I just got everything back on the motor and plugged in and now the car starts, revs to 2000 and dies. Any ideas? Things i could have done wrong? Thanks
gordo is offline   Reply With Quote
Old 03-03-2007, 04:53 PM   #2 (permalink)
striker_1818's Avatar
I HATE Stephanie
contact AJP
striker_1818 is offline   Reply With Quote
Old 03-03-2007, 05:04 PM   #3 (permalink)
Don't think it has anything to do with there stuff, anyone know anything about the Air Assist Valve, if i damage that would it cause the car to die?
Part number 8:
Old 03-03-2007, 05:14 PM   #4 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
Originally Posted by striker_1818
contact AJP
^^^^werd
Old 03-03-2007, 05:14 PM   #5 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
dammm. this is not good.
Old 03-03-2007, 05:16 PM   #6 (permalink)
CaliGuy's Avatar
AJP=
Old 03-03-2007, 05:17 PM   #7 (permalink)
I HATE Stephanie
Part number 8:
that's why i said contact them. they know their stuff more than any of us do and troubleshooting directly with them would be your best bet instead of us giving random answers we know nothing about that could cost you an eye and a leg
Old 03-03-2007, 05:19 PM   #8 (permalink)
Streethonda06's Avatar
Greg
my intake fell off once and that made my car die at about 2k then die...
check that stuff... or check the sencor on the intake and stuff... i dono just try everything
Streethonda06 is offline   Reply With Quote
Old 03-03-2007, 05:19 PM   #9 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
do you mean because i dameged that will it cause the car to die.?
Old 03-03-2007, 05:20 PM   #10 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
Check all connections see if you have a leaking Intake manifold.....
If not send Ecu back to hondata sounds like a bad reflash
Not good man not good at all
fiji06si13 is offline   Reply With Quote
Old 03-03-2007, 05:23 PM   #11 (permalink)
the plastic portion of the air assist valve feels loose, i don't know if a vaccuum leak from there would cause the car to die or not. Checked the intak side of things, all seems good.
Old 03-03-2007, 05:24 PM   #12 (permalink)
Phantom Poster
fiji06si13's Avatar
Justin aka Mr. JT
Something is not hooked up right or ECU is Toast...........
Old 03-03-2007, 05:42 PM   #13 (permalink)
I've worked on plenty of cars before and never been so stumped.
Old 03-03-2007, 06:12 PM   #14 (permalink)
I think it's the Immobilizer System Indicator
Old 03-06-2007, 02:13 AM   #15 (permalink)
BATANG CITY JAIL's Avatar
there is a marker line on that part number "8", when you installed it back it should be on the right spot/or aline.
you dont have enough fuel pressure thats y the car wont start......
Old 03-06-2007, 02:38 AM   #16 (permalink)
Air assist valve
When the engine is cold, the intake air bypass control thermal valve sends air to the injector.
The amount of air is regulated by engine coolant temperature. Once the engine is hot, the intake air bypass control thermal valve closes, stopping air to the injector."
Hope that helps :) Sounds like you need to re-install Number 8
Old 03-06-2007, 09:45 AM   #17 (permalink)
stevenshizzle's Avatar
Steven
Subscribed. Installing AJP IM in about 3-4 weeks.
stevenshizzle is offline   Reply With Quote
Old 03-06-2007, 01:12 PM   #18 (permalink)
make sure that you put the part number 8 back on the same spot
Old 03-06-2007, 06:04 PM   #19 (permalink)
Ep3racer954's Avatar
FG*SQUAD #87
intake air bypass control thermal valve... wow.. IABCTV?? lmao
Ep3racer954 is offline   Reply With Quote
