2010 civic mpg - 8th Generation Honda Civic Forum
Old 12-06-2012, 11:13 AM   #1 (permalink)
2010 civic mpg
Hey guys,
I've had my 2010 Civic LX since July 2010, bought it new. I just hit 20,000 miles on it a few days ago.
Ever since day 1, I've been managing about 22/23 miles per gallon, which is pretty low considering what others on the board are getting.
I do not drive her hard, just average driving, and 50% highway 50% city.
I manage about 270 miles per fill-up, so 270 miles/12 gallons = about 23 mpg.
I have never had a check engine light, replaced the cabin and air filters in the summer, and I go to the dealership to get my oil changed.
What could contribute to this poor mpg? I see people with older models and some hit 30 mpg, what are some factors that can be affecting my mpg?
Thanks!
arthur01 is offline
Old 12-06-2012, 11:20 AM   #2 (permalink)
Brian
i get better than that in my Si, with spirited driving. are you manual or auto? do you use cruise on the highway?
when is the last time you checked your tire pressures? at what rpm do you shift?
TiRex is offline   Reply With Quote
Old 12-06-2012, 01:06 PM   #3 (permalink)
it is auto, i don't use cruise control on the highway, and haven't checked tire pressure in a while, i'll check it today
arthur01 is offline   Reply With Quote
Old 12-06-2012, 01:50 PM   #4 (permalink)
Brian
yea check tire pressure, that helps quite a bit. i like to keep mine around 32-34. also, whenever possible on the highway, use cruisecontrol. it used to be in older cars, you could get better mileage without, but now ours are computer controlled throttle anyway, so might as well let the computer sort it out.
Old 12-06-2012, 03:05 PM   #5 (permalink)
could there be something bigger that has an effect on mpg than just my tire pressure? there's no check engine light, so i'm wondering what could be causing my mileage to be so poor
Old 12-06-2012, 03:24 PM   #6 (permalink)
Brian
cant think of too many mechanical factors at that low of a mileage, maybe some one else can jump in and suggest some...
all i can think of are environmental (temp, elevation) and driving style factors (quick starts, cruise control, is AC on). for me that's the difference between 21mpg, and 36mpg.
Old 12-06-2012, 03:33 PM   #7 (permalink)
Chase's Avatar
Chase
You are doing it wrong... Here is telemetry from my Si with a K24A2 in it.
And here is the one with my CIvic Hybrid
You should be in between the two. Both of these taken on the high way at cruising speed with some distance traveled... Start using your cruise control it helps a LOT.
Chase is online now   Reply With Quote
Old 12-06-2012, 05:10 PM   #8 (permalink)
wow, those are amazing figures, i'd be happy if i could hit 30 mpg. i really have to look into this, it's bothering me that i have such crappy mpg
Old 12-06-2012, 05:11 PM   #9 (permalink)
Originally Posted by TiRex View Post
all i can think of are environmental (temp, elevation) and driving style factors (quick starts, cruise control, is AC on).....
do quick starts play a huge factor? i usually wait 30 seconds to let it warm up, then drive, and i take it really easy when driving in the morning (not that i drive like a maniac anyways)
i wonder if this is affecting it
Old 12-06-2012, 05:44 PM   #10 (permalink)
Brian
by quick start i meant taking off quickly from a stop, like a green light or stop sign.
Old 12-06-2012, 07:16 PM   #11 (permalink)
Is most of your driving when the engine is warm, or is a bunch of short trips with a mostly cold engine? That makes a big difference.
Also, if you're really doing city, like stopping every block, vs suburb or highway makes a big difference too even if you have some traffic on the highway
bludragon is offline   Reply With Quote
Old 12-06-2012, 07:21 PM   #12 (permalink)
killin's Avatar
Special.K
try draining your tank and add a fuel additive called techron and if you wanted to put 91-93 octane to really clean out the engine. then go back to regular gas and recal your mileage.
killin is online now   Reply With Quote
Old 12-06-2012, 09:07 PM   #13 (permalink)
Try just for one tank fill up to drive like a complete grandma on her way to bingo. It will either prove you drive with a lead foot or show that it doesn't make a difference.
evandonald is offline   Reply With Quote
Old 12-06-2012, 11:26 PM   #14 (permalink)
Chase's Avatar
Chase
Put a can of sea foam in it..
Old 12-07-2012, 01:37 AM   #15 (permalink)
mis
check the spark plugs and also the clogged air filter
mis is offline   Reply With Quote
Old 12-07-2012, 08:39 AM   #16 (permalink)
Road_Clam's Avatar
Rich
There's so many variables to your final mpg # . I'm averaging about 25-26mpg . This from very easy driving, and staying OUT of the I-VTEC . I also have the common bolt on mods, exhaust, CAI, and the TBS. I also add a bottle of Chevron Techtron fuel system cleaner about every 3rd month. CT keeps your oxy sensors clean, so they function properly and efficiently.
Road_Clam is offline   Reply With Quote
Old 12-07-2012, 09:51 AM   #17 (permalink)
Steve
Try burning 2 tanks of 93 octane and then go back to the recommended 87.
If that doesn't help, search for a thread that shows how to burn a half can of sea-foam directly into your intake manifold.
My 06 ex 4dr (56,500 miles) w/auto gets about 26 city & 35 hwy@80 mph and 38mpg at 70mph.
I never jack rabbit start, at a stop sign or red light.
I use the recommended 5w20 oil and 87 octane gas.
I have a K&N air filter, which fits in my OEM air box.
My only trick is to use 2 tanks of hi-test gas (93), from Shell/Texaco twice a year.
carpayments4life is offline   Reply With Quote
Old 12-10-2012, 11:39 AM   #18 (permalink)
faizan.mumtaz's Avatar
Faizan
i noticed my mpg on my Si to jump up 3-4 mpgs after switching to synthetic motor oil.. its worth a shot but iv heard its bad to go back to regular oil after upgrading. However i believe if you want the engine to last you the longest then you should switch and you can go longer on synthetic oil than you can on regular between oil changes.
faizan.mumtaz is offline   Reply With Quote
Old 12-10-2012, 03:16 PM   #19 (permalink)
jumanjaq143's Avatar
Mark
Don't run higher octane, that is just a waste of money.
95% of the time when it is a new car like this, its due to driving tendancies.
Also you're still under warranty no? Ask Honda
jumanjaq143 is offline   Reply With Quote
Old 12-10-2012, 04:06 PM   #20 (permalink)
Brian
yea going to have to agree here, not sure why people are recommending using premium fuel on a car that uses regular...
2010 Honda Civic Si Sedan vs. 2010 GTI hoosier11 Civic SI 224 02-03-2011 11:49 AM
9/4/2010 - etMeet 2010 (8th Gen Civic / S2000) EvansTuningDotCom Mid-Atlantic 10 09-09-2010 08:09 PM
9/4/2010 - etMeet 2010 (8th Gen Civic / S2000) EvansTuningDotCom North-East 15 09-09-2010 08:04 PM
9/4/2010 - etMeet 2010 (8th Gen Civic / S2000) EvansTuningDotCom Evans Tuning 7 09-09-2010 04:48 PM
