mix and match brakes? - 8th Generation Honda Civic Forum
Old 11-26-2012, 11:53 PM   #1 (permalink)
fg2churppin's Avatar
hey 8th i have a quick question to ask.
im running ebc slotted/drilled rotors on ebc pads.
but the pads are almost done theyre making alot of noise.
i have my oem pads with loads of meat left on them, i was wondering if i threw the oem pads on the ebc rotors would it work out fine?
thanks in advance!
fg2churppin is offline
Old 11-27-2012, 01:41 AM   #2 (permalink)
Otsi's Avatar
Its normally not a good idea to mix used pads/rotors. Used pads are going to be "broken in" to whatever rotor they were on previously, and may cause premature wear to your rotors. Pads really aren't very expensive, and IMO it would be best to just buy a new set.
Otsi is offline   Reply With Quote
Old 11-27-2012, 04:22 PM   #3 (permalink)
you will be fine as long as you bed them correctly. i normally go thru 2-3 sets of pads before i need rotors. as previously stated the pad will form itself to match the rotor.
07taffyfa5 is offline   Reply With Quote
Old 11-27-2012, 07:17 PM   #4 (permalink)
thanks guys, should i re-surface the rotors just to be safe or its not needed, ill be fine by simply just throwing on the other set of pads?
how should i bed them in properly?
fg2churppin is offline   Reply With Quote
Old 11-27-2012, 07:24 PM   #5 (permalink)
asndragonboii's Avatar
What he said
No need to resurface rotors unless you're getting a shimmy or vibration during braking. I doubt you'll find a shop willing to resurface your slotted / drilled rotors too.
Different pad manufacturers have different burnishing procedures. I just go up to 30mph and do a hard stop down to 5mph. Do that about 10 times.
Old 11-27-2012, 07:26 PM   #6 (permalink)
Originally Posted by asndragonboii View Post
damn really...why is that, only works on blanks?
Old 11-27-2012, 07:27 PM   #7 (permalink)
It could damage their cutting tips
Old 11-27-2012, 07:29 PM   #8 (permalink)
okay thank u for the advice ill do that when i put the new pads on.
guess i wont bother trying to re-surface the rotors either..
i do have the stock blank rotors but im sure the ebc ones should just stay on..
Old 11-27-2012, 10:41 PM   #9 (permalink)
yea you could leave them on. the other reason that most shops wont mess with them is because drilled/slotted rotors are actually weaker than blanks and they run the risk of not only damaging their equipment but cracking your rotor as well. drilled/slotted rotors arent really needed for street use and the benefits of them on the track are marginal as well.
Old 11-28-2012, 06:08 PM   #10 (permalink)
thanks for the helpful info!
ill be throwing my oem pads on the ebc rotors soon, my brakes are making the most annoying noise in the world i cant take it anymore.
Old 11-28-2012, 07:47 PM   #11 (permalink)
lou10788's Avatar
Lou
Oem pads ftw bro! Lol
lou10788 is offline   Reply With Quote
Old 11-28-2012, 08:45 PM   #12 (permalink)
i prefer ebc redstuff for street use...i can stop wayy shorter than any other si on stock pads...just make sure if you get these to get the autozone rotors with 2 year warranty because they will eat up about 2 sets before theyre halfway done.
Old 11-28-2012, 08:56 PM   #13 (permalink)
ill prob get the yellow stuff pads later on, dont have extra money now and my oem pads have a ton of life on them so might as well throw those on to save money and have some brakes..
Old 11-28-2012, 09:24 PM   #14 (permalink)
good plan sir
Old 11-28-2012, 10:31 PM   #15 (permalink)
the noise is strange, it goes away after i wash my car but after driving for a while it comes back.
the stranger thing is when im turning left the noise gets worst vs if im turning right theres no noise at all.
when braking the noise is extremely loud, even when not braking im hearing these sounds..
should i get the calipers lubed when putting in the new pads?
Brakes upgraded to JDM Euro R Accord brakes pengful Suspension and Brakes 36 11-01-2012 02:16 AM
do drum brakes need changing of pads or something similar like disc brakes? tigerboy0213 Suspension and Brakes 6 04-06-2011 01:15 PM
Si brakes front brakes on an EX coupe celery gt-5 Suspension and Brakes 3 04-28-2010 06:53 AM
Paint Match Pic: Poor Match? korrupted Introduction & Pictures 30 02-24-2010 05:58 PM
Why disc brakes have replaced drum brakes? johnwaynes Suspension and Brakes 16 06-25-2008 11:46 PM
