Civic si clutch
Ho guys i have recently join to this awesome community. Well I've been having troubles with the clutch but yesterday it quit working.
the mechanic check it; and he said its the auxiliary bomb so I bought it but it didn't work either now I took it to the dealer and they can't find the issue any ideas???.My car is a 2006 civic Si |
![]() Join Date: Mar 2010
Jesse
Get your front tires off the ground put it in first and then give it gas then push the clutch. If your RPMs jump up in that means your clutch is somewhat working. Let us know after that. It could be as simple as ajusting the rod on the back of your clutch pedal.
My air to air cooled 2.3 Whipple build thread. http://www.8thcivic.com/forums/car-b...ple-2-3-a.html Last edited by Fsrider; 11-18-2012 at 12:57 AM. |
Jesse
Have you dropped a transmission and swapped a clutch before? I have and You can move that rod enough so that you can not get into gear even with stock clutch . Obviously you should check the fluid as well. These cars have a very finicky adjustment I have spent a lot of time with my elbow up around the gas pedal trying to get it perfect.
My air to air cooled 2.3 Whipple build thread. http://www.8thcivic.com/forums/car-b...ple-2-3-a.html |
Andrew
If you can't get the car into gear when the engine is running the clutch is partially engaged. There are 2 scenarios here, either the master or slave cylinder is failing and not releasing the clutch all the way (cheapest fix) causing it to stay partially engaged.... or the clutch is dragging because it's warped, coming apart, or there's a problem with the pressure plate / release fork.
Hope it's the first scenario. The rest require the trans to come out ![]() Either way, a dragging clutch is not good. do not continue to drive like this or you will put severe stress on your synchros trying to overcome that dragging clutch. |
#10 (permalink) | |
#11 (permalink) |
Andrew
They couldn't find the issue? I hope it only happens intermittently, or else that's a pretty sh*tty dealer.
If it's intermittent it could most likely be the master cylinder |
| What is a best clutch kit for 2007 civic si? | Daren07si | Clutch & Transmission | 29 | 03-29-2012 11:24 AM |
| 06 civic si clutch? | jaxsi | Civic SI | 3 | 05-08-2010 10:28 PM |
| Civic clutch help.. | icewind69 | Mechanical Problems & Technical Chat | 7 | 07-25-2006 04:20 PM |
