Loud vibrating when cold - 8th Generation Honda Civic Forum
Old 11-15-2012, 11:18 AM   #1 (permalink)
Josh
So, since the temps have dropped where I live, I've noticed a very prominent noise when the car is cold.
- It sounds and feels like a VERY loud vibrating noise.
- It only happens when the car is cold. After it warms up, it's gone.
- The sound/vibration is very deep in pitch.
- The sound is only present when in reverse. As soon as the clutch starts to engage in, the vibration and noise starts, even if I'm not moving. When the clutch is not engaged, there is no noise.
- When shifting from 1st into lower gears while traveling forward, it is very rough.
- Whenever I hit a bump, I get a loud thud that sounds more like it's coming from the right/front side of the car.
- When if I cruise down the road, release the clutch, an slowly start to re-engage the clutch, the vibrating and noise happens, though not as loud.
Again, all of these symptoms only happen when both the car and outside temps are cold!
We had one warm day earlier this week and none of these symptoms occurred at all.
At first I was thinking that maybe it's the clutch going bad. But if that were the case, I would think it would happen regardless of outside temps and regardless of whether the car was cold or not.
I'm lost. I'm hoping it's not the clutch because I don't have the money to replace it. I already had two quotes, jut in case. One was $800 and the other was $1125, both of which I think are ridiculous.
What else could it be? And why would it only happen when both the car and outside temps are cold (30-40 degrees Fahrenheit). If the outside temp is warm, nothing happens. If the outside temp is cold but the car is warm, nothing happens. But if its cold outside and the car is cold, it sounds horrible!
Sent from my iPhone using AutoGuide.com Free App
LXCoupeGuy is offline
Old 11-15-2012, 11:47 AM   #2 (permalink)
Josh
Btw my car is completely stock.
LXCoupeGuy is offline   Reply With Quote
Old 11-15-2012, 11:53 AM   #3 (permalink)
Dyno-FA5's Avatar
The sound you are describing is normal. Our motors sound like diesels when it is cold out. My car does it and my wifes crv did the same thing.
Dyno-FA5 is offline   Reply With Quote
Old 11-15-2012, 11:56 AM   #4 (permalink)
Josh
No. This is not normal. I've had this car for two years and it's never done this. This is a completely abnormal sound and vibration.
Old 11-15-2012, 12:06 PM   #5 (permalink)
testify's Avatar
Sounds pretty normal. All cars do this on cold start up.
The only thing I can figure is that your hydraulic engine mount is going bad.
testify is online now   Reply With Quote
Old 11-15-2012, 12:10 PM   #6 (permalink)
BFrisco's Avatar
Whenever it's cold I think I have the same thing but not as often as it seems to happen to you. When I release the clutch slowly in first or reverse it sounds like a metal on metal slight vibration. Sometimes louder than others. But once the pedal is out it stops. It only happens when letting out the clutch in first and reverse. Happened last winter too and stopped when it got warmer out and just started coming back recently. I don't know what it is either.
BFrisco is offline   Reply With Quote
Old 11-15-2012, 12:33 PM   #7 (permalink)
Josh
I was reading somewhere else that it may be a bad motor mount. I'm gonna try and get it in the shop within the coming week.
My sound isn't really so much metal on metal. I'm not really sure how to describe it.
I'm also gonna see if I can get it on recording tomorrow morning. I also will have a friend engage the clutch when cold, with the hood open, to check visual engine vibration.
It'll be tomorrow before I'll be able to report on anything.
Old 11-15-2012, 12:43 PM   #8 (permalink)
testify's Avatar
Cold fluid in the mount = vibration
Once the fluid warms up = no vibration
Again, this sounds fairly normal.
Old 11-15-2012, 12:46 PM   #9 (permalink)
Josh
Then why didn't it do it last winter?
Old 11-15-2012, 12:50 PM   #10 (permalink)
testify's Avatar
I don't know about St. Louis, but here in New England there was no such thing as last winter. It barely dipped below 50 degrees.
Also, it may have done it last winter and you just didn't notice. Let me ask you, do you see anything wet around any of the mounts?
Old 11-15-2012, 12:53 PM   #11 (permalink)
Josh
http://repairpal.com/low-rumbling-so...ine-mounts-598
Found this. Everyone is saying exactly what I've been saying. I am narrowing it down to a blown mount.
Old 11-15-2012, 12:53 PM   #12 (permalink)
Josh
Sorry testify. I would have noticed this. This is something that is VERY loud. It's not just a subtle noise.
Old 11-15-2012, 04:40 PM   #13 (permalink)
i dont know if this is the same thing youre referring to but many people complain of metal on metal "knocking" when temps get cold. many have attributed it to the hydraulic timing chain tensioner not getting pressure fast enough when it is cold or a stretched chain/worn guides. only when its cold though and goes away in under 20 seconds to 40 seconds.
07taffyfa5 is offline   Reply With Quote
Old 11-15-2012, 11:39 PM   #14 (permalink)
its the passenger side motor mount going bad.
aznsyco is offline   Reply With Quote
Old 11-16-2012, 02:11 AM   #15 (permalink)
I had similar symptons....the temperature dropped where I lived. When I would start the car it sounded like a harley until it warmed up and then would go away. I would hear this rumbling/vibration in P, R, and D. You say the sound is coming from the front right side...sounds like a bad motor mount. That was my problem and when I took it to get it fixed the problem when away. It was fixed under the 5 year power train warranty. The 8th gen civics have this problem often.
Praveen Kumar Sinha +: Honda Civic engine vibration fix
c03rcion is offline   Reply With Quote
Old 11-16-2012, 09:04 AM   #16 (permalink)
Josh
I thought it was a 60k mile warranty.
Old 11-16-2012, 09:09 AM   #17 (permalink)
Luis
I am actually having the exact same problem. I have all those symptoms lol
LTFA182 is offline   Reply With Quote
Old 11-16-2012, 04:21 PM   #18 (permalink)
Josh
I took it to the shop this morning and had them take a look at it. All of the mounts are in good condition, with exception to one which has a little more play than it should. But they don't think it's enough to really be the cause of the symptoms.
Regardless, just in case, I'm going to have the mount replaced anyway in about a week (can't really afford it right now). I'll keep posting as I find out more. If it stops with the mount replacement, then great. If not, it looks like replacing the clutch will be next.
By the way, I'm at 78K miles. I've been driving sticks for a while so I don't understand why I would have to replace the clutch so soon when all of my other MT vehicles' clutches lasted between 150-200k miles.
Old 11-17-2012, 03:13 AM   #19 (permalink)
Drumminchick's Avatar
Christen
I am having the EXACT same issue in my 2008 EXL Coupe Auto with 76k miles. The noise is HORRIBLE. It is only getting worse by the day. I took it to a mechanic this past week and they had no clue.
How much is this motor mount? Sigh. I am ready to trade the damn thing in, I am so upset! UGH.
Drumminchick is offline   Reply With Quote
Old 11-17-2012, 09:55 AM   #20 (permalink)
if you suspect its your mount grab your buddy if you have one and borrow the mount off his car to see if yours is the problem before you go blowing money on something without 100% diagnosis.
Loud Sound on Cold Start winchester0101 Mechanical Problems & Technical Chat 7 01-07-2013 04:22 PM
loud growling/grinding when cold and in reverse 11dx Mechanical Problems & Technical Chat 2 04-02-2012 03:36 PM
loud vibrating noise at start up samoajoa Mechanical Problems & Technical Chat 31 01-03-2012 04:15 PM
Loud vibrating noise when it rains hard? WTF rainking1978 Mechanical Problems & Technical Chat 4 10-14-2010 01:57 PM
Loud Suspension in the cold Tennisjon2002 Mechanical Problems & Technical Chat 5 11-26-2008 04:05 PM
