Old 02-21-2007, 10:42 PM   #1 (permalink)
high pitched sound when braking
ok, recently its turned a little cold here in NY, and i've started noticing this problem .... when my cars cold ... i.e. around 15-20 mins after starting up, when i apply the brakes, even if i dont hit them real hard i hear this screetching sound that goes like "eeeeeeeeeeeeee" untill my car comes to a complete stop .... this doesnt happen if i start brakin gently like wayyy wayyyy before a light or something, but anything sudden or normal braking causes this sound ...
i was wondering if thats because of the weather or if it shouldnt be happening at all ??? couple of months back my brake oil was leaking and honda had to replace some of the braking stuff .... could this be a related issue ???
thanks !
HeLLz aNgeL is offline   Reply With Quote
Old 02-21-2007, 10:45 PM   #2 (permalink)
udumkid's Avatar
Rene....
Same here.
udumkid is offline   Reply With Quote
Old 02-21-2007, 10:56 PM   #3 (permalink)
Sli(ks's Avatar
Sounds like your brake pads are worn out
Sli(ks is offline   Reply With Quote
Old 02-21-2007, 11:32 PM   #4 (permalink)
udumkid's Avatar
Rene....
I have 8k on my car, I really doubt they are worn down already. I broke in the brakes properly(never applied 100% of braking force before the first 300 miles). Im thinking its the actual material the brake pads are made of,seems like the lower the temperature is the harder the material gets thos making noise when applying the brakes at low speeds right before coming to a complete stop.
Old 02-21-2007, 11:34 PM   #5 (permalink)
mines 4k ... still havent even gone in for my first oil change ... brake pads cant wear out that fast.... maybe i can give the dealership a mouthfull and hope they replace my brakepads :P
worth a try
Old 02-21-2007, 11:38 PM   #6 (permalink)
udumkid's Avatar
Rene....
worth a try
but make shure you dont come in with any after market up grades beacuse I garantee you that the service advisor will tell you "since you have an after market intake, your brakes pads have worn down since all the vtec you have been hitting" lol
Old 02-21-2007, 11:41 PM   #7 (permalink)
striker_1818's Avatar
I HATE Stephanie
thanks !
I'm in NY as well and mine don't make that sound...
striker_1818 is offline   Reply With Quote
Old 02-22-2007, 12:27 AM   #8 (permalink)
Mine make that sound as well, usually the first time i use the brake after parking overnight or when I leave work. Sound is gone after tho.
evolution921 is offline   Reply With Quote
Old 02-22-2007, 03:19 AM   #9 (permalink)
Same here folks, I began hearing this high pitched squeel upon starting out for the first time that day, and after the car has sat parked for a few hours. Only have 6k mi on my sedan (16 mo. old) breaks and cold weather shouldn't affect breaks this soon. The squeeling sound is extremely loud especially in the morning. Taking sedan into service today, will report remedy, hopefully.
subfree is offline   Reply With Quote
Old 02-22-2007, 09:56 AM   #10 (permalink)
udumkid's Avatar
Rene....
Please keep us posted.
Old 02-22-2007, 12:08 PM   #11 (permalink)
I remember speaking to a technician about this problem and I was told that it's because of the condensation, which can be explained if the weather turns cold and if you've left your car in the garage overnight.
It'll go away after a couple of brakings. No worries.
chutster is offline   Reply With Quote
Old 02-22-2007, 12:46 PM   #12 (permalink)
xmx250's Avatar
I'm in N.Y. I have 3000 miles and mine are quiet.
xmx250 is offline   Reply With Quote
Old 02-22-2007, 12:50 PM   #13 (permalink)
I HATE Stephanie
same as mine and i park it out in my driveway not even the garage lol
Old 02-22-2007, 01:46 PM   #14 (permalink)
Smooth Moderator
wing_gundam's Avatar
Civic Type Stock
thanks !
sounds like dust or something between the pad and the disc to me?
anyone else?
wing_gundam is online now   Reply With Quote
Old 02-22-2007, 01:52 PM   #15 (permalink)
I HATE Stephanie
probably ice on the rotor due to driving condition and temperatures going from high 30s during the day melting the snow to low 20s at night....
Old 02-22-2007, 01:54 PM   #16 (permalink)
lovin_it06's Avatar
James
anyone else?
That is what I was thinking:)
lovin_it06 is offline   Reply With Quote
Old 02-22-2007, 08:23 PM   #17 (permalink)
Took the sedan in for a check up with regard to the squeeling breaks, clanging sound comming from the front dash area. Service said nothing wrong with brakes, cleaned out some dust and dirt, said brakes are fine. As you can guest said did not hear any sound from dash area going over any bumps. They probably would have looked at me crossed eyed if I would have mentioned sepintine belt fix for droning sound at 15k rpm. So I guest I'll have to look for another honda service spot in the NYC area. Lastly, one of the mechanics put a whole in my rear bumper when backing out of a tight spot. they are going to replace entire rear bumper and back light. What a day cats!What else should I BE ASKING FOR. They did cop to the accident and said the light and bumper should be in around 3 days, where they will call me to bring the sedan in, and provide me with a loaner car until work is done. need feed back?
Old 02-22-2007, 09:08 PM   #18 (permalink)
Smooth Moderator
Civic Type Stock
Hahah your in the bronx, you should be lucky that they didnt give you just a bumper back! haha jk. That sucks still but I really won't worry about the squeaking.
Proper Sound Dampening ballplaya4237 I.C.E., Electrical, Security, & Navigation 23 09-29-2008 07:03 AM
popping sound from right front(passenger side) sickyute Suspension and Brakes 14 11-24-2007 07:19 AM
New Civic Coupe LX - 140 CRAP SOUND SYSTEM :( Need help to change hondapower Civic Coupe And Sedan 30 10-16-2007 06:21 PM
high pitched sound when braking HeLLz aNgeL Mechanical Problems & Technical Chat 4 12-16-2006 12:27 AM
Sound Quality in the 06 civic hamm I.C.E., Electrical, Security, & Navigation 9 12-30-2005 09:41 AM
