Old 02-21-2007, 02:57 AM   #1 (permalink)
R18 break in oil consumption
I've got an 07 EX coupe, and I've got around 1700 miles on it right now. I've noticed that it's lost a little bit of oil. I've read that consumption in the first few thousand miles is normal but I've only read that in the context of Honda's performance engines (mainly K series) and not the R18.
Is it normal for the R18 to use a little bit of oil this early in its life?
rationull is offline   Reply With Quote
Old 02-21-2007, 03:11 AM   #2 (permalink)
Kidekat's Avatar
Yes, just keep an eye on it.
Kidekat is offline   Reply With Quote
Old 02-21-2007, 06:29 PM   #3 (permalink)
I lost some factory oil too, but once I got an oil change I haven't lost any since.
damb is offline   Reply With Quote
Old 02-21-2007, 06:42 PM   #4 (permalink)
With 8000+ on my LX sedan, between oil changes there is still some oil loss!
Old 02-21-2007, 09:29 PM   #5 (permalink)
moxom's Avatar
^^ Here, here^^
moxom is offline   Reply With Quote
Old 02-22-2007, 10:21 AM   #6 (permalink)
And how much is "little bit" and "some" so we can offer a better response? 1 quart is significant, so how many miles until 1 quart is lost will be my question. I haven't calibrated our new R18's dip stick, so I don't know how much oil it takes to go from bottom to top mark on the dip stick.
On our D16Y8 motor, it takes 0.5qt from min to max, with a 3.3qt sump.
VelociRacer is offline   Reply With Quote
Old 02-22-2007, 06:44 PM   #7 (permalink)
A "little bit" in my case is not what I would consider a significant amount, maybe about and eighth of an inch off the full mark on the dipstick. I was just curious as to whether any consumption should be expected from a healthy R18 when new. Sounds like it's fine.
Oil Change DIY ethlar Engine 358 01-06-2010 05:36 PM
Oil Life Elmacho Civic SI 33 01-05-2009 09:36 PM
R18 Oil Change datbacker59 Mechanical Problems & Technical Chat 5 01-02-2007 01:51 PM
changing oil after break in IWANNAGOFAST Mechanical Problems & Technical Chat 6 01-02-2007 11:26 AM
