Closed Thread
Old 02-19-2007, 10:13 AM   #1 (permalink)
berlinas2k2's Avatar
254whp on 75
Anyone with SI having 3rd Gear problems>?
Just wondering if its becoming common,
both myself (07 SI Sedan 2,608miles), and my bro's (07 SI Sedan 1,500miles) are having slight issues sometimes with 3rd gear. Every now and then it will grind into 3rd gear when upshifting from 2nd. Its not that bad yet, and im planning on taking it to the dealership to have it checked out, but as far as i know, the're arent any service bulletins or service recalls out on it yet....
Anyone else have this problem?
berlinas2k2 is offline
Old 02-19-2007, 10:38 AM   #2 (permalink)
xmx250's Avatar
If you do a search you will find a ton of stuff.
Mine has the third gear notchiness. However it has never grinded or popped out on me. Alot of people have had problems with third gear and said alot of the symptoms go away after changing the tranny fluid to something like Amsoil or Gm syncromesh.
xmx250 is offline
Old 02-19-2007, 10:53 AM   #3 (permalink)
RSPjean's Avatar
Jean
im going to the dealer today to ge that checked out cuz that happens to mines
RSPjean is offline
Old 02-19-2007, 01:26 PM   #4 (permalink)
I don't beliieve the dealer will help you on this one unless they put in the newer Honda MTF - though that isn't that good either. I had the same problem and switched over to Amsoil Synthetic MTF:
https://www.amsoil.com/storefront/mtf.aspx
You'll need 2 quarts (1.7 QT MT Capacity) and a new crush washer for the MTF drain plug - same washer as the oil drain. Make sure the car is level - it's easiest if you take it to your trusted mechanic and he puts it on a lift. The Amsoil makes the MT silky smooth - much better than before.
SiCop is offline
Old 02-19-2007, 01:36 PM   #5 (permalink)
goofygamer's Avatar
Its better for them to come over to you and let them test drive your car from a cold start. Like don't drive it at all that day, and if they're willing to come over and check it out, then let them test drive it. I think that's the only way the 3rd gear problem shows up, is when its driven from a cold start.
goofygamer is offline
Old 02-19-2007, 01:40 PM   #6 (permalink)
firmhonda: unleashing shaved beavers upon the unsuspecting since 2008
dentrecords's Avatar
Please search.
Search for "3rd gear".
Originally Posted by firmhonda
I like it
beards and shaved beavers
dentrecords is offline
Closed Thread
TSB for 3rd gear wassup61 Mechanical Problems & Technical Chat 7 08-17-2007 05:19 PM
07 Problems todsulli Mechanical Problems & Technical Chat 33 01-29-2007 10:38 AM
3rd Gear... nnorton Civic SI 21 01-13-2007 07:25 PM
Problem with 3rd Gear? imtim25 Mechanical Problems & Technical Chat 57 08-23-2006 08:28 PM
