Old 02-16-2007, 10:11 PM   #1 (permalink)
ajrich's Avatar
Grinding noise when turing left.
My 07 EX sedan makes a grinding noise from the front left when making a slow left hand turn. This does not happen with a higher speed turn. My thoughts are that it is maybe a wheel bearing, but not sure. Just wanted to get your opinions before making a trip to the dealer.
ajrich is offline   Reply With Quote
Old 02-16-2007, 10:20 PM   #2 (permalink)
20strong's Avatar
Marcus
Go to the dealer. It could be a couple of things though. If your CV joint got dirt in it it will start to grind at the knuckle rather quickly.
20strong is offline   Reply With Quote
Old 02-16-2007, 10:57 PM   #3 (permalink)
MBK
does it happen when its cold
MBK is offline   Reply With Quote
Old 02-16-2007, 11:30 PM   #4 (permalink)
ajrich's Avatar
it happens when it is cold or warm
Old 02-19-2007, 04:27 AM   #5 (permalink)
XtatiC's Avatar
Jay
i have same problem.... 07 lx
XtatiC is offline   Reply With Quote
Old 02-19-2007, 01:59 PM   #6 (permalink)
I have same problem on my 06si. I'll be taking it in soon. My take is that it is either the CV or a bearing.
vetkiller is offline   Reply With Quote
Old 04-12-2007, 10:10 PM   #7 (permalink)
WHODATA??
organiz3d_chaos's Avatar
Billy
I have same thing, but I can't recreate it every time. I have an 06 Si with 16,000miles...
organiz3d_chaos is offline   Reply With Quote
Old 04-12-2007, 10:16 PM   #8 (permalink)
ajrich's Avatar
It must have been dirt and salt from all the snowy months, because I haven't heard it since the snow has went away and I got a good car wash done.
Old 04-12-2007, 10:28 PM   #9 (permalink)
WHODATA??
Billy
Hmm, still seems a little troubling to me though that it just went away...
I'll just drive it till my wheel falls off :)
Damn dirt roads... shoulda bought a WRX :)
Old 04-26-2007, 01:40 PM   #10 (permalink)
there are other threads out there which might help. i just had the dealer replace my front left strut because it was making a clunking noise at very low speeds. i couldn't hear it at higher speeds due to road noise.
beancenzo is offline   Reply With Quote
Old 04-26-2007, 02:15 PM   #11 (permalink)
Bootsie's Avatar
Brooklynn
Is it a loud noise? Mine kind of does that, but it is more of something that I can feel not hear. It is not bad so I have not worried about it, but if it is a problem that others are having I might want to have it looked at.
Bootsie is offline   Reply With Quote
Old 04-26-2007, 02:20 PM   #12 (permalink)
benmunger's Avatar
Is it a cluncking, springing, or rubbing rubber noise?
this was a big issue on EPs and RSXs..
it turned out to be the spring spinning in the strut.
benmunger is offline   Reply With Quote
Old 04-27-2007, 11:51 AM   #13 (permalink)
He's right the first time. It is a wheel bearing. He turns left and it makes the noise so it's the right front wheel bearing.
jayjr98 is offline   Reply With Quote
Old 04-27-2007, 01:12 PM   #14 (permalink)
WHODATA??
Billy
Mine is not real loud, i have to have the radio down to hear it and it is not every time.... it is actually really hard to recreate... i would call it more of a "buzzing" though
Rev Matching/Gear Grinding CaliGuy Garage 46 08-31-2007 07:13 PM
Pulling and grinding noises Sirbelch Suspension and Brakes 0 02-02-2007 10:18 PM
07 Problems todsulli Mechanical Problems & Technical Chat 33 01-29-2007 11:38 AM
left turns in Russia SUCK! marc-o-lishuz Water Cooler 11 11-27-2006 03:30 AM
Spinning noise gradually increasing as RPM goes up joonoo Mechanical Problems & Technical Chat 0 09-03-2006 02:54 AM
