LinkBack (4) Thread Tools Display Modes
Old 11-24-2007, 11:52 PM   #61 (permalink)
windforce's Avatar
I didn't notice any difference before and after...
I can always turn A/C off while in Defrost mode... I hear the difference when on and off...
I did this steps serveral times, and still didn't notice the differece..
"factory setting" does not exist on my car?
windforce is online now   Reply With Quote
Old 11-26-2007, 02:16 AM   #62 (permalink)
nelsonr31's Avatar
Maybe there's a difference between 06' and 07'. My 06' Si had this annoying factory setting. BUT NOT ANY MORE
nelsonr31 is offline   Reply With Quote
Old 11-26-2007, 05:10 AM   #63 (permalink)
windforce's Avatar
Has anyone figured out how to return to the default setting of AC on when in defrost mode? I have been reading about this for a while both here and on other forums but no one seems to know how to revert back to the factory setting should the need arise.
Edit:
I found instructions in a Honda Element forum explaining how to return to the factory setting. I have modified them to apply to the Civic. I have also tested them and it works!
To deactivate automatic a/c feature:
1. Select dash vent button
2. Turn fan knob to off position.
3. Turn temperature knob all the way to coldest setting
4. Turn vehicle off.
5. Hold down both air re-circulation button and a/c button while starting the vehicle.
6. Continue holding for 7 seconds until air re-circulation button stops flashing.
7. Now when you select defrost mode the a/c compressor will turn on but so will the a/c light on the a/c button. You can now press the a/c button and turn the compressor on or off. Even when you turn the car off the setting will be stored.
To reactivate automatic a/c feature:
1. (Select defrost mode button)
3. Turn temperature knob all the way to the coldest setting.
7. After this, the a/c light will turn to green and it's back to factory setting!
works great!
Old 11-26-2007, 05:18 AM   #64 (permalink)
M.U.R.D.E.R
COMplex's Avatar
Actually....
Factory setting: when press front defrost, the AC light doesn't come on, and AC is not on.
After doing this: when press front defrost, the AC light comes on automatically, and turn on AC.
Can anyone tell me how to return to factory setting??? I hate this mod... >_< plz..
Mine is the opposite...
Factory setting: when press front defrost, the AC light doesn't come on, and AC is on.
I will try the procedure dentrecords suggested. I don't use deforst all that much, but sometimes when my passenger is changing songs on my radio she accidentally hits defrost and I don't notice it until I try and speed up that my A/C is on lol
» Supercharged 2006 Honda Civic Si Coupe
» Information/Teaser Video | ROTM | Carbon8mag Feature!
» HondaArmy.com
COMplex is offline   Reply With Quote
Old 11-26-2007, 05:27 AM   #65 (permalink)
windforce's Avatar
The only thing I hate about this mod is that:
when you press defrost, the AC goes on automatically (AC light goes on as well), then when you press "face", the AC doesn't go off automatically... so you will be getting cold air.
Factory mod: though AC goes on automatically when u press defrost, it goes off automatically when u press "face".
Am I correct?
Old 11-26-2007, 05:51 PM   #66 (permalink)
JDMoore's Avatar
Will this procedure also solve the air continuously coming through my vents even when I have the A/C and fan speed completely off?
Example: Even if I have both set to off a small amount of air STILL comes through not a ton but still enough to annoy me greatly me. If I set the temperature control all the way to red the air will turn hot also without the A/C being on or Fan speed set to even 1.
Will this help?
JDMoore is offline   Reply With Quote
Old 11-29-2007, 09:10 PM   #67 (permalink)
Will this help?
I don't think I've seen a car where this doesn't happen. Hey, you need air to breathe, right?
peter_x is offline   Reply With Quote
Old 11-29-2007, 11:33 PM   #68 (permalink)
nelsonr31's Avatar
Will this help?
Just turn the recirculation button on. This will close off the flap that allows fresh air in. With this turned on air will not be present at your vents. Do you ever notice that when you drive with everything off you feel more air as opposed when your car's not moving. The recirculation button is there for extremely cold weather when you need to warm up the interior quickly. This procedure has nothing to do with what annoys you.
Old 12-07-2007, 08:00 PM   #69 (permalink)
I just did the fix today in my Civic. I can't wait to see if it helps my gas mileage!
DJH3279 is offline   Reply With Quote
Old 12-31-2007, 11:19 PM   #70 (permalink)
usakicksass's Avatar
Craig vanAntwerp
WTF!!! How did you EVER figure this out? If you did it yourself you are one sharp cookie! Glad you are American and not working for Al Queasadea.
usakicksass is offline   Reply With Quote
Old 01-01-2008, 10:10 PM   #71 (permalink)
buurner's Avatar
So I'm guessing this does not affect the a/c in the summer right? Because Memphis gets hot as hell.
buurner is offline   Reply With Quote
Old 01-07-2008, 01:47 PM   #72 (permalink)
Fielder0024's Avatar
Leo
This will give you the option to turn it off when using the defrost vents.
1. Turn car on.
2. Turn temperature knob all the way cold and turn the fan knob to off.
3. Put vent location to "face"
4. Turn car off
5. Hold down the Recirculation Button and the A/C Button.
6. Hold down both buttons and turn the key all the way to the on position.
7. Keep both buttons depressed until one of the lights blink a few times, then you get a solid green light once the change has been made. Then let go.
8. See if it works by putting the fan on in Defrost. You should see the A/C light turn on and you should be able to turn it off.
I did this but once I let go of the button the light went away. I put on the defrost but the a/c light wont go on or off.
Fielder0024 is offline   Reply With Quote
Old 01-23-2008, 10:36 AM   #73 (permalink)
rwburnett's Avatar
Randy Burnett
I have done the mod and it works - many thanks to all who contributed. However, is there any way to make it so the A/C NEVER TURNS ON unless I press the A/C button myself? I'm in Indiana (0% - 100% humidity) and am very in-tune to when I do and don't need to condition the incoming air. I don't like the A/C flipping itself back on when I go between various air deflection modes...
rwburnett is offline   Reply With Quote
Old 01-23-2008, 10:51 AM   #74 (permalink)
Smooth Moderator
wing_gundam's Avatar
Civic Type Stock
No, I don't believe you can do that.
Sorry! But if you've done the mod its pretty easy to be sure its off when you press the button and turn the light off.
Trying to sell? Read the updated for sale forum rules here
wing_gundam is offline   Reply With Quote
Old 01-23-2008, 11:04 AM   #75 (permalink)
dentrecords's Avatar
Nope.
You have to turn it off manually each time.
Originally Posted by 2fast4u2
yee hawww
Old 02-18-2008, 11:08 PM   #76 (permalink)
Liu
Liu's Avatar
This mod is great, complete control over our AC's.
Liu is offline   Reply With Quote
Old 05-10-2008, 01:41 AM   #77 (permalink)
I found this thread a few months ago and changed the setting. It's most useful for me in transition weather (spring, autumn) when I need just a bit of
'maintenance' defrost all around on wet days, but I don't want to be frozen out of the car and/or have to constantly adjust the temperature control.
Very handy. I don't know of any other vehicle that allows this kind of control. Too bad...
Robert Barr is offline   Reply With Quote
Old 05-11-2008, 05:59 PM   #78 (permalink)
Originally Posted by SiCop View Post
I did this about 4 weeks ago and my gas mileage went from 22 - 23 mpg to 25 - 27 (31 all highway). This saves a lot of fuel - I don't like it when a car tells me how I should use it's features. Now, if I could get ALL of the doors to unlock when I stop instead of just the drivers door - his is a major PIA!!
i don't mean to hijack but i have the instructions on how to make the car unlock all doors on turning off the car if that is what you meant. if you need them let me know and i will post them when i get home from mothers day dinner here. (thank god for internet on phone!)
octomobiki is offline   Reply With Quote
Old 05-11-2008, 06:05 PM   #79 (permalink)
Produce Wizard
jlannoo's Avatar
You can change the locks so they all unlock but only if you have a '07 or newer. It actually shows you how to do this right in the manual
Jamie - 2008 NHBP Si coupe -
jlannoo is offline   Reply With Quote
Old 11-30-2008, 07:12 AM   #80 (permalink)
Look in the manual. It tells you how to program your locks so they all open when you put it in park.
gondo is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/29193-why-my-c-always.html
Hard Parking :: View topic - rtards on honda-tech This thread Refback 12-17-2007 08:24 PM
Hard Parking :: View topic - rtards on honda-tech This thread Refback 12-10-2007 03:30 AM
Hard Parking :: View topic - rtards on honda-tech This thread Refback 12-10-2007 02:41 AM
Hard Parking :: View topic - rtards on honda-tech This thread Refback 12-10-2007 02:40 AM
Installed A/C Kit Myself in my Civic DX civicboy Mechanical Problems & Technical Chat 17 05-26-2008 04:00 AM
How Much Horsepower Do You Think The A/C Takes From Your Engine civicboy Mechanical Problems & Technical Chat 21 08-09-2007 10:35 PM
A/C Cooling? Hondalways Civic Coupe And Sedan 3 05-21-2006 08:15 PM
Finally Got A/C Kit For DX Civic civicboy Mechanical Problems & Technical Chat 6 04-06-2006 01:03 AM
Hello! + A/C lap Introduction & Pictures 2 03-21-2006 11:32 PM
