#21 (permalink) | |
Joey
#23 (permalink) | ||
don't you just love this site?
![]() search · FAQ · rules · report bad post · learn how to spell Quote:
#25 (permalink) | |
#26 (permalink) |
I did this about 4 weeks ago and my gas mileage went from 22 - 23 mpg to 25 - 27 (31 all highway). This saves a lot of fuel - I don't like it when a car tells me how I should use it's features. Now, if I could get ALL of the doors to unlock when I stop instead of just the drivers door - his is a major PIA!!
#29 (permalink) |
Check this out, my a/c does not come on when I turn on the defrost..
I thought this automatic with my previous civic it came on auto...I was ready to disable the a/c with defrost, but it never comes on ...somebody miracoulousy disabled it for me at honda! |
#30 (permalink) |
By default the A/C does come on when you hit the defrost but you won't see the A/C light come on and then it stays on without you realizing it until you hear the A/C compressor running. The posted procedure allows you to see when the A/C is on and turn it off when you're using defrost.
#32 (permalink) | ||
#33 (permalink) | |
Donald Trump FTW!!!
Justin aka Mr. JT
#35 (permalink) |
Has anyone figured out how to return to the default setting of AC on when in defrost mode? I have been reading about this for a while both here and on other forums but no one seems to know how to revert back to the factory setting should the need arise.
Edit: I found instructions in a Honda Element forum explaining how to return to the factory setting. I have modified them to apply to the Civic. I have also tested them and it works! HVAC.jpg To deactivate automatic a/c feature: 1. Select dash vent button 2. Turn fan knob to off position. 3. Turn temperature knob all the way to coldest setting 4. Turn vehicle off. 5. Hold down both air re-circulation button and a/c button while starting the vehicle. 6. Continue holding for 7 seconds until air re-circulation button stops flashing. 7. Now when you select defrost mode the a/c compressor will turn on but so will the a/c light on the a/c button. You can now press the a/c button and turn the compressor on or off. Even when you turn the car off the setting will be stored. To reactivate automatic a/c feature: 1. (Select defrost mode button) 2. Turn fan knob to off position. 3. Turn temperature knob all the way to the coldest setting. 4. Turn vehicle off. 5. Hold down both air re-circulation button and a/c button while starting the vehicle. 6. Continue holding for 7 seconds until air re-circulation button stops flashing. 7. After this, the a/c light will turn to green and it's back to factory setting! Last edited by RBP LX; 03-18-2007 at 11:06 PM. |
#40 (permalink) | |
Donald Trump FTW!!!
Justin aka Mr. JT
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/29193-why-my-c-always.html
| Hard Parking :: View topic - rtards on honda-tech | This thread | Refback | 12-17-2007 07:24 PM | |
| Hard Parking :: View topic - rtards on honda-tech | This thread | Refback | 12-10-2007 02:30 AM | |
| Hard Parking :: View topic - rtards on honda-tech | This thread | Refback | 12-10-2007 01:41 AM | |
| Hard Parking :: View topic - rtards on honda-tech | This thread | Refback | 12-10-2007 01:40 AM | |
