Old 02-13-2007, 11:23 PM   #1 (permalink)
zelmac's Avatar
Edson
Turning off car after speeding
Is it bad to turn off a car immediately after you have been speeding? I've heard that you should wait a couple of minutes before turning it off, why is that necessary.
zelmac is offline   Reply With Quote
Old 02-13-2007, 11:32 PM   #2 (permalink)
jonesthewine's Avatar
Carlos Castaneda
Maybe it's not necessary, but giving the cooling system time to remove some of the excessive heat from an engine that's been driven hard is not a bad idea.
jonesthewine is offline   Reply With Quote
Old 02-13-2007, 11:34 PM   #3 (permalink)
dsg2003gt's Avatar
LOL, im not really sure if the car knows youve been speeding. You should ask it...
You should do the speed limit so that you can turn the car off right when your done driving.
dsg2003gt is offline   Reply With Quote
Old 02-13-2007, 11:38 PM   #4 (permalink)
Camry Loverz
AbsoluteGG's Avatar
Steven
i've never heard of such a thing
AbsoluteGG is offline   Reply With Quote
Old 02-13-2007, 11:40 PM   #5 (permalink)
BATANG CITY JAIL's Avatar
its bad if you have a turbo...but if you drive it like normal for 5 minutes, it should be okey...
Old 02-14-2007, 05:57 AM   #6 (permalink)
Kidekat's Avatar
On turbocharged vehicles, turning off a car after a hard run causes "coking". This is the cooking of motor oil left on the bearing. This can lead to premature bearing failure. Hence the invention of turbo timers, to assist with lowering temperature before shut down.
I woudl imagine the same principle would apply to NA vehicles, but just not to the extent of the turbo crowd.
I drive normally when I am near my destination.
Kidekat is offline   Reply With Quote
Old 02-14-2007, 11:03 AM   #7 (permalink)
xmx250's Avatar
This an interesting thread. I've heard this stuff before but i didnt believe it.
How does the turbo timer work??
xmx250 is offline   Reply With Quote
Old 02-14-2007, 11:09 AM   #8 (permalink)
Kakashi's Avatar
It just keeps the engine running after you leave. Just for a few minutes, then turns itself off.
Old 02-14-2007, 11:43 AM   #9 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
Batman & Robin always seemed to get away with it.
GeezerSi is online now   Reply With Quote
Old 02-14-2007, 12:54 PM   #10 (permalink)
Why does this seem like something that can make the car easily stolen?
Old 02-14-2007, 08:24 PM   #11 (permalink)
A turbo timer works after you remove your key from the ingition. Your sterrig wheel is locked. If you lock our doors when you walk away then it is just as easy to steal one of these cars as any other car sitting not running.
MHill is offline   Reply With Quote
Old 02-14-2007, 08:31 PM   #12 (permalink)
dsg2003gt's Avatar
he never said he had a turbo...
so all of your posts are irrelevant.
Old 02-14-2007, 08:44 PM   #13 (permalink)
gbae007's Avatar
That's what coolant is for!
Old 02-14-2007, 11:42 PM   #14 (permalink)
Berto's Avatar
The turbo timer in my RX-7 is wired into my ebrake. So If someone jumps in and tries to steal it, and puts down the ebrake the car turns off.
not only does it cause coking but with turbos when you run something that hot and just turn off the car. This obviously gets rid of oil pressure in the system, therefore the oil film between the bearings is gone. If you have driven hard enough those bearings are come in contact and actually fuse together. ( Bad)
I wouldn't recommend running any car hard and shutting it off. I have no firsthand reason as to why not to on an N/A car but you run into issues that might occur with Heat soak. Funny ways different engine parts expand and contract at different rates.
Berto is offline   Reply With Quote
Old 02-15-2007, 02:08 AM   #15 (permalink)
zelmac's Avatar
Edson
I don't have a turbo, but if you have been at high RPM that could damage something, just by the change in temp.
Old 02-15-2007, 03:05 AM   #16 (permalink)
Kidekat's Avatar
In case the E-Brake was bypassed, I bought an Autolock to combat the car theft problem associated with turbo timers. Some Autolocks fits perfect on the clutch pedal, making the car not driveable.
If you are going to steal the car, you'll have to push it.
Old 02-15-2007, 10:22 AM   #17 (permalink)
Will
This turbo timer that you guys are taking about, does it come with all turbos stock when buying a car or that is a aftermarket product?
ReFlex is offline   Reply With Quote
Old 02-15-2007, 10:28 AM   #18 (permalink)
20strong's Avatar
Marcus
Mostly an aftermarket product to my knowledge.
20strong is offline   Reply With Quote
Old 02-15-2007, 04:51 PM   #19 (permalink)
The Sticker Man
blue rocket's Avatar
GrafiXpressions.com
bleh, NA cars don't need to be cooled down after driving hard.
blue rocket is offline   Reply With Quote
Old 02-19-2007, 03:35 AM   #20 (permalink)
IMTHEPUNISHER's Avatar
Eazy fix: Unless you're Michael Schumacher, don't "speed". Dumbass.
IMTHEPUNISHER is offline   Reply With Quote
Mustang owners are teh kewl ryryninja Garage 117 03-08-2007 03:03 PM
***The Definitive 1000 Mile Review: Civic EX MT*** GalaxyGrayMark Civic Coupe And Sedan 26 01-10-2007 09:44 AM
almost had a car accident! i heard BIG BANG from my car! NoMoreHonda Mechanical Problems & Technical Chat 15 10-25-2006 03:24 AM
My fuggin passenger seat broke. amdhunter Mechanical Problems & Technical Chat 44 10-21-2006 11:20 AM
