Luigi
don't worry to much...just drain a little bit of it out.... you will be good.. having to much oil is not bad for the motor but it does add a little stress on the block.... i would ratter have more then less... don't want to have a spun rod bearing that would suck... check the dip stick and have it between the two dots and you will be good
#7 (permalink) | |
Ben
Check the stick. Drain until you're at the top mark for full. Take your time and don't over drain it. I actually did thus to my moms Kia the other day. Loosen these drain plug and use it as a control for the oil flow. Let it glow for a few (15-20) seconds slowly and then insert th's plug. Check the stick. And repeat unti) the level is properly lowered. Sent from my DROID BIONIC using Tapatalk |
| 23,000 miles on single oil change, Lab recommends 25,000 miles for next change :) | deltatechx | Mechanical Problems & Technical Chat | 25 | 01-07-2012 12:32 AM |
| thoughts-first oil change, mtf change | norcal450 | Civic SI | 17 | 01-05-2012 06:45 PM |
| Change for the sake of change | 07gen8Civic | Garage | 39 | 12-16-2008 09:25 PM |
| To change or not to change ... another synth thread | Falchon1 | Civic SI | 11 | 08-30-2008 02:21 AM |
| First oil change/trans fluid change BEFORE 3500 miles? | djdefcon | Civic SI | 7 | 08-22-2006 08:36 AM |
