Old 02-07-2007, 03:20 AM   #1 (permalink)
sdc
sdc's Avatar
Sean
Oil Life Question - Not what you're thinking.
I was just thinking about something...
Mobil 1 synthetic isn't supposed to be changed until something like 10,000+ miles, right? If that's the case then 5,000-6,000 miles is fine between oil changes. The oil life gauge is calibrated for about 3,000 miles between changes. So why am I stressing about changing my oil (Mobil 1 synth) when I just had it done 3,000 miles ago?
I was getting really nervous because I'm at 5% right now, and I usually changed the oil in my old car every 4,000-5,000 miles. But unless I'm mistaken, I'm at less than 1/2 the recommended life of my oil.
Any problems with just resetting the minder and ? On that note, what're the positive/negative sides to changing my oil earlier than recommended (5,000-10,000 miles)?
sdc is offline   Reply With Quote
Old 02-07-2007, 04:18 AM   #2 (permalink)
JeShUa's Avatar
swagger so tight
nope it basically tracks miles.. and reminds you to change your oil :].. feel free to reset it
Old 02-07-2007, 10:01 AM   #3 (permalink)
Vince's Avatar
Stephen "Vince" Carter
The minder oil life thingy takes several factors into consideration, like operating temps, among other things and does not operate on miles alone. I will respectfully disagree with 1) changing any oil @ 10K miles, and 2) paying any attention to that minder thing.
But alas, many, many, opinions out there on oil and changes. Go with whatever you feel comfortable with!
Vince is offline   Reply With Quote
Old 02-07-2007, 12:36 PM   #4 (permalink)
drexp2000's Avatar
I have 3500 miles in the car and my oil life indicator is at 40%... I don't think it is set to track 3000 miles. And I think you are due for an oil change. hahahha.
drexp2000 is offline   Reply With Quote
Old 02-07-2007, 03:30 PM   #5 (permalink)
8thCivicNut's Avatar
Dealer told me not to worry bout mileage, just wait for the wrench light to take my car in for oil changes or service.
8thCivicNut is offline   Reply With Quote
Old 02-07-2007, 04:00 PM   #6 (permalink)
I didnt get my first oil change until 6500 miles.
max500 is offline   Reply With Quote
Old 02-07-2007, 04:20 PM   #7 (permalink)
dREsTrUcTiON's Avatar
When to change the oil depends on how hard you drive the car each day/weekend, if you go on any roadtrips, etc. I don't go past 5000 miles just to be on the safe side. It's not too expensive to change compared to the cost of a whole new motor!
dREsTrUcTiON is offline   Reply With Quote
Old 02-07-2007, 04:21 PM   #8 (permalink)
new06Civic's Avatar
Honda Engineer use oil life sensor to estimate the viscosity of a fluid and detect the changes that occur in the viscosity when a lubricant breaks down. For 2006 Civic and Ody applications, the device can indicate when an oil change is needed. Based on the engine operating conditions and accumulated engine revolutions, the onboard computer in engine oil life and displays it as a percentage.
I drove 5600 miles at 15% before the last oil change. I use the recommended oil. If you REV your Si very hard, you will not get a lot of miles in between oil change.
Honda Owner Manual
new06Civic is offline   Reply With Quote
Old 02-07-2007, 04:26 PM   #9 (permalink)
mhobby's Avatar
I just changed my oil for the first time Tuesday and had 15% on the minder and 6440 on the odometer.
mhobby is offline   Reply With Quote
Oil Life Elmacho Civic SI 32 12-02-2008 03:01 PM
Oil Change DIY ethlar Engine 251 12-01-2008 10:46 PM
oil life indicator RedneckSi Civic SI 5 12-13-2006 03:44 PM
Oil life question ? Merged Threads ...WillSI07... Civic SI 21 11-18-2006 11:10 PM
