R18 K&N SRI CEL - 8th Generation Honda Civic Forum
Old 02-06-2007, 11:14 PM   #1 (permalink)
Non-FG*Squad_Member 37
ominous8204's Avatar
Chris - Mmmm, VTEC!!!
R18 K&N SRI CEL
Alright, here is the deal. I bought a K&N SRI for my R18, from K&N. I installed it and I'm getting a CEL. An insider at Honda agreed to help me...behind Honda's back...if I get the CEL code. I took the car to 2 places to get the code, Advance Auto Parts and Auto Zone. Neither one of their scanners will read the car. One came up with "Link Error" and the other got "Operator Error". Does anyone have any ideas on what is the problem? I was thinking it could be the MAF sensor. The guy at Advance said to put back my stock intake and take it to Honda to let the get a code, because, according to him, the CEL will stay on...is this true? I've done the 60-90 miles test, and I've done the battery disconnect once (I'm trying again tonight). If anyone has any ideas or suggestions please let me know.
I will keep you guys updated.
ominous8204 is offline
Old 02-06-2007, 11:27 PM   #2 (permalink)
gbae007's Avatar
Might try and see if the installation was perfect. Make sure things are fitting tight and the clamps are fully twisted in.
If you find someone with a Scangauge II that will read and reset OBII error codes.
Old 02-06-2007, 11:37 PM   #3 (permalink)
Do you know of any places that might use or carry a Scangauge II?
ominous8204 is offline   Reply With Quote
Old 02-06-2007, 11:55 PM   #4 (permalink)
Scrodums
If an insider at Honda agreed to help you, then he can use the scan tool to pull up the code, no?
My best advice is to take out the SRI, all of it and work back from square one. It's an SRI, so it should take 1 hour tops.
Old 02-07-2007, 12:08 AM   #5 (permalink)
The girl at Honda can use their tools because it has to be written up for the tools to be used.
And with the SRI reinstall, I'm gonna try that this weekend.
I'm not getting any side effects from the CEL, just the light. The intake sounds and performs amazingly well.
Old 02-07-2007, 05:44 AM   #6 (permalink)
lowerlevel's Avatar
dave
i doubt that its in limp mode.. also may affect ur mpg.. im sorry to hear this though, i was about to order the k&n sri. ? did u unplug the battery before the install.
lowerlevel is offline   Reply With Quote
Old 02-07-2007, 07:29 AM   #7 (permalink)
Emong3's Avatar
if the CEL popped out after installing the SRI it must be one of the sensors attached to the intake tube. It may be loose or one of them was not installed in the new tube.
Emong3 is offline   Reply With Quote
Old 02-07-2007, 08:46 AM   #8 (permalink)
I installed the sensor on the tube. It is called the MAF sensor.
I did unplug the batter during the install.
Last night I unplugged the battery for 30 minutes. Went and reconnected it. Then started the car. Let it run for a couple minutes, and then turned the car off. As of right now, that is working with no CEL. I will go this morning and see if it turns back on.
Old 02-07-2007, 12:09 PM   #9 (permalink)
gbae007's Avatar
scanguage.com or search @ thinkgeek.com
Old 02-07-2007, 10:27 PM   #10 (permalink)
CEL back on, stayed off until I pressed the gas. I'm strongly leaning toward the MAF tripping because as soon as I touched the gas, the intake sucks in all that air, freaking out the sensor.
Old 02-08-2007, 10:38 PM   #11 (permalink)
m1k3's Avatar
what is it with r18's + intakes and CEL's...
m1k3 is offline   Reply With Quote
Old 02-09-2007, 01:07 AM   #12 (permalink)
Scrodums
Could be an air leak as well. Pretty easy to pinpoint it with an SRI, but like I said reassemble the unit.
Old 02-09-2007, 01:24 AM   #13 (permalink)
Well, If I knew..this problem would be solved.
Old 02-09-2007, 01:25 AM   #14 (permalink)
How can you do a test on the SRI's? I thought about doing the soapy water test...but that wouldn't work because it would suck in the water instead of blowing bubbles.
Old 02-11-2007, 06:44 PM   #15 (permalink)
Ok, sorry for such the long time for getting a sound clip...but hear is one now. A SUV flipped on the interstate...which is the reason I turn the camera to it...
Old 06-06-2007, 03:54 PM   #16 (permalink)
90and90's Avatar
Location: Amundsen-Scott South Pole Station, Antarctica
Todd
I brought mine to my mechanic, he said my engine was running really lean, I have an CAI and Exhaust, does anyone think it has to do with the backpressure and the oxy sensor's not having enough pressure to read? I have a MT so if I throw it in neutral and the Air Conditioning is on it almost always die's on top of that, im going post this somewhere else, also since my CEL is on and I cant pass inspection with a check engine light on... my mechanic plugged it onto an obd and he said it was running lean, the other place's that had obd said it didnt give any code's... this is crap, i love my CAI and I dont want to take it out but it looks like i may have to.
90and90 is offline   Reply With Quote
Old 06-07-2007, 11:31 AM   #17 (permalink)
DetachmentBravo's Avatar
William
This is incredibly common when someone upgrades to a "high flow" air filter. I worked at a service station for a while and the head mechanic there, a fellow named Jim, absolutely hated K&N filters and the like. To this day we can't exactly explain why it occurs, but do know that we serviced at least one car a week that had a CEL that was solved by going back to an OEM filter.
DetachmentBravo is offline   Reply With Quote
Old 06-07-2007, 08:39 PM   #18 (permalink)
Looking back at a previous post, this:
came off very crude, I appologize m1k3.
AEM sri (r18) r18addict CorSport 15 02-26-2008 03:01 AM
Which SRI is CEL free and the best? chriskurn Bolt-Ons And All-Motor 33 04-19-2007 09:51 AM
aem sri 4 R18??? 8thex Forced Induction And Nitrous 3 02-01-2007 10:11 AM
possible? Si SRI in a R18? GETxERxDONE Bolt-Ons And All-Motor 3 11-14-2006 02:00 PM
Si AEM SRI have CEL? tim711 Mechanical Problems & Technical Chat 0 09-25-2006 02:36 AM
