after header intsall im getting a weird sound.
i just installed my obx header on my si. i have an cold air intake, obx header straight back to the muffler. no resonator or cat. im getting a weird noise at 3000+ rpms. i don't know if my intake is whistling really hard since theirs less restriction of the exhaust or i just have an exhaust leak. it almost sounds like a turbo is spooling up.
Dan
For the guys saying it's normal, it may not be. It's very very very hard to tell what the problem is by just a description. When you get a chance get your car up on jack stands and start the car cold and feel for any leaks.
#10 (permalink) |
1* Man
Stephen
Have someone record you as you drive by while making the sound. Do you have a tbs? that sometimes also makes a whistling sound. If it's more of like a raspy woosh kinda sound, its normal. It depends on your header/cat back setup. Sometimes it will sound like that, depending on the quality of your parts and the size.
if you have an exhaust leak, you will most likely feel it in peformance, you will probably lose tq as it messes up fueling and backpressure. Last edited by Steve42790; 02-28-2012 at 10:12 AM. |
#12 (permalink) |
Kelly A.
are you tuning the car to the changes you have made? i had the same sound at first . then reflashed with my flash pro using a map from the software that had simular mods . sound gone . and sounds better and feels better. get FLASHPRO if you want you car to come alive.
#13 (permalink) |
Kelly A.
and check your header where it bolts up and look for black carbon at the bolt together . if you see black thats probly your leak .
will have to drive it about a tan of gas to see the black carbon . |
#14 (permalink) |
i recently bought and installed a tsudo 4-2-1 header with high flow cat and noticed a metallic rattle noise. at first i thought maybe exhaust leak,no. then maybe engine harmonics resonating through pipes so i wrapped the header with header wrap and treated it with 1500 deg high temp silicon spray. now its ugly as hell and the rattle is still there. almost to the point of ripping it off and using it for an anchor for my conoe i tried putting iton the lift at work while my buddy slowly increased the rpm, BAM! horrible rattle coming from the flex pipe. cutting it off next week and welding in a new one of higher quality. let you know how it goes.
#15 (permalink) |
Alright folks, here it is. Tsudo header with high flow cat rattle noise FIXED! In my last post i said i was going to replace the flex pipe so i did and the rattle is completely gone. i am now very happy and relieved i found the fix. I bought a flex pipe from summit racing. the dimensions you need is 4 inches length by 2.5 inches i.d. ( internal diameter ). the part was a little expensive but well worth it. you will need to weld it in for best results. Part number VPE-60804. Price 38.60.
#16 (permalink) |
Im getting the "zzzz" noise aswell but im pretty sure its the same as other people have said with the thin piping. I dont have a flex pipe, nor exhaust leaks.
Sent from my iPhone using Tapatalk |
#18 (permalink) |
Jeff
I have the same kind of noise problem, i know its not the header hisssss, i will find out tomorrow when i put it back on the lift, hoping it just something touching a heat shield or something easy to fix, otherwise i love the sound of my invidia header and full race exhaust
| DIY: Fuel Pressure Guage Intsall | midnitesi | DIY Honda Civic Engine | 26 | 03-26-2012 10:28 AM |
| Weird sound after header instal l | gooky4u | Bolt-Ons And All-Motor | 5 | 02-25-2012 03:51 PM |
| Weird Sound | manoman | Mechanical Problems & Technical Chat | 7 | 10-22-2009 01:26 AM |
| Weird air sound | drush | Mechanical Problems & Technical Chat | 4 | 08-27-2009 07:59 AM |
| weird sound?!?! | falkon57 | Mechanical Problems & Technical Chat | 6 | 04-08-2007 03:01 AM |
