Closed Thread
Old 01-15-2008, 02:37 AM   #101 (permalink)
Am i the only one that can't see pics?
lyttleviet is offline
Old 01-15-2008, 03:03 AM   #102 (permalink)
reaper702's Avatar
*DIY-HONDATA IMG Install-Q Style
check that one out
reaper702 is offline
Old 02-11-2008, 12:25 PM   #103 (permalink)
BTRobertson's Avatar
B.T. Robertson
I had someone ask me this question and I wasn't sure how to answer it. If the gasket prevents heat soak from the engine block to the intake, where does the heat go then? For example, if the block is - for the sake of argument - 200 degrees F. Now, with the stock gasket, it siphons off 40 degrees to the intake, which means it's core temperature would be 160 degrees. Is this correct logic so far?
So now we put a gasket in that prevents this heat soak to the intake (doesn't prevent it 100%, I know, but lowers the transfer)...now the 40 degrees (above example) doesn't transfer to the intake - where does it go? Does the engine block get HOTTER because the heat transfer isn't taking place? If that's the case, does the coolant system work overtime to keep the block cool since the heat transfer prevention is actually heating the block up more than it was before?
Or is this logic flawed when it comes to the way an engine block handles heat? My buddy seems to think that preventing heat from transferring will increase the overall temperature of the block, potentially causing more damage. Is this at all true? Thanks Honda gods! :)
BTRobertson is offline
Old 02-22-2008, 05:22 PM   #104 (permalink)
kekekekevin's Avatar
KeKeKeKeViN
The intake manifold ONLY has a little thing to do with the heat transfer from the head. I would say the coolant and cooling fan do the 99% of the work, while the IM only does 1%. Plus, it has been out for a long time, and no one mentions he has any overheating problem.
kekekekevin is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/mechanical-problems-technical-chat/27974-diy-hondata-img-install.html
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-19-2008 11:45 PM
DIY/install index - LOOK HERE BEFORE ASKING FOR A DIY - 8th Generation Honda Civic Forum This thread Refback 01-09-2008 12:24 PM
K&N Short Ram Intake DIY Install for Si, with Pics! dowNNshift Do It Yourself Articles 88 01-18-2008 01:25 PM
How easy is it to install the Hondata IMG......... Dwn4nythng Bolt-Ons And All-Motor 14 05-20-2007 06:11 PM
Need DIY!!! Want DIY on hondata gasket install xxmstajxx Do It Yourself Articles 3 12-29-2006 04:51 PM
Hondata IMG Install ? on 06 Si Nox Bolt-Ons And All-Motor 4 09-14-2006 01:58 PM
IMG install?!? SonicK20Z Bolt-Ons And All-Motor 1 06-21-2006 06:45 PM
