Old 01-31-2007, 06:33 AM   #1 (permalink)
1stk20z3's Avatar
Casey
Angry Need help with 2nd Gear its annoying!and it hurts!
Hey new here been on honda-tech this whole time just foun uot about this place! okay back to the point does anyone have a problem with second gear, cuz when itry to shift quikly from 1st to 2nd at a high RPM like a racing situation no matter how hard i pull it wont go to gear and it grind like hell makes me sick! . i have to shift a little slower to get into gear! i bet u guys think my hands are faster than my feet huh, but thats not the case i wen it sarted happening i thought that too but then i started making sure my clutch was to the floor before i shift and still all u hear is my trans screaming for me to stop! and 2nd gear is supposed to be an easy gear to get into, most people have a hard time wit 3rd but i have no problem wit 3rd. please help what should i do!? any advice would help!Thanks!
1stk20z3 is offline   Reply With Quote
Old 01-31-2007, 07:33 AM   #2 (permalink)
hondasi006's Avatar
i had this problem when it was warm outside but then when it got colder out then i had no problem,
hondasi006 is offline   Reply With Quote
Old 01-31-2007, 09:17 AM   #3 (permalink)
Vince's Avatar
Stephen "Vince" Carter
Most people are changing fluid to Amsoil Syncromesh and that's eliminating shifting problems. I have two quarts on order now. Search on "syncromesh" and you'll find some discussion about it.
Vince is offline   Reply With Quote
Old 01-31-2007, 09:19 AM   #4 (permalink)
06blaksi's Avatar
All I did was pull the shifter to the left as you pull back into 2nd. But I think I might go with Synchromesh in the spring
Old 01-31-2007, 09:39 AM   #5 (permalink)
Fluid swap ftw...
Old 01-31-2007, 08:37 PM   #6 (permalink)
1stk20z3's Avatar
Casey
would my dealership do the tranny flush uner warrenty just wondering!
Old 01-31-2007, 08:47 PM   #7 (permalink)
SiRyan's Avatar
My second gear acts like that too! It's a B!tch! I usaully shift earlier than redline around 7700-7900 in order for it not to grind. My 3rd is fixed by changing my MTF with GM Synchromesh.
SiRyan is offline   Reply With Quote
Old 01-31-2007, 08:50 PM   #8 (permalink)
Vince's Avatar
no they won't. They won't see it as "defective" and there's no bulletin or recall (an admission by Honda that there is some level of problem with the car) telling them how to handle this complaint should they be presented with it. You could ask, you never know.
Old 01-31-2007, 08:53 PM   #9 (permalink)
blackhawk black si's Avatar
Im fine with 2nd gear but it is 3rd gear that some times doesnt want to go in it sucks have we uncovered an issue here it seems like alot of people are having this problem. I was told it would be remedied by changing the bushings.
blackhawk black si is offline   Reply With Quote
Old 01-31-2007, 08:54 PM   #10 (permalink)
airportguy770's Avatar
Dave
Try using Amsoil, UPS just delivered my 2 quarts today. Hopefully I'll have it done by this weekend. People have been getting good results by swapping the fluids Theres a DIY on here also, doesnt look to difficult
airportguy770 is offline   Reply With Quote
Old 01-31-2007, 09:00 PM   #11 (permalink)
SiRyan's Avatar
I have the comptech ss and aluminum shifter cable bushings, I guess I'll have to order the base bushings and wait and see if 2nd gear still acts up like it does.
Old 01-31-2007, 09:31 PM   #12 (permalink)
Vince's Avatar
I'm holding out for my 2 quarts of Amsoil to get here by Friday so I can take the care to my service center and get it changed!
Old 01-31-2007, 09:39 PM   #13 (permalink)
our k series trannies are known for this gear grind, people suggest changing the tranny fluid, try using the new Acura MTF.
douglas is offline   Reply With Quote
Old 02-10-2007, 01:03 AM   #14 (permalink)
articsilber323's Avatar
i have changed my fluid to amsoil mtf
now my third gear is PERFECT
but i still have the bad 2nd gear grind at high rpm's
articsilber323 is offline   Reply With Quote
Old 02-10-2007, 01:06 AM   #15 (permalink)
vicSi's Avatar
victor
you need to move your intake! gears are hitting it.
vicSi is offline   Reply With Quote
Old 02-10-2007, 01:20 AM   #16 (permalink)
ive had this problem before i installed any mods
its not my intake
Old 02-10-2007, 02:59 AM   #17 (permalink)
SiRyan's Avatar
I have the oem intake box.
Old 02-10-2007, 03:56 AM   #18 (permalink)
Gr3y Goose's Avatar
Goose
and the intake wouldnt hit the gears anyway...wtf
Gr3y Goose is offline   Reply With Quote
Old 05-03-2007, 06:21 PM   #19 (permalink)
jocasti's Avatar
X2
jocasti is offline   Reply With Quote
Old 05-03-2007, 06:45 PM   #20 (permalink)
tommyroo's Avatar
I did the amsoil change and fixed the third gear problem but I'm 90% the second gear grind at WOT didn't start until after the switch to new tranny fluid. Otherwise I'm sure I would of noticed when I put my SS on and did a bunch of runs.
I still take it up to the redline 1 -> 2 but I just take my time with the shift and it avoids the grind. I seem to keep more speed that way then shifting before 8,000.
I know it's not me since I can shift as fast as I want any other gear.
tommyroo is offline   Reply With Quote
Has anyone takin their SI back to dealer for a notchy feeling 2nd gear yet? 06redsi Mechanical Problems & Technical Chat 11 10-02-2007 03:37 AM
07 Problems todsulli Mechanical Problems & Technical Chat 33 01-29-2007 11:38 AM
2nd Gear.... leenangle Civic Coupe And Sedan 27 08-22-2006 10:22 PM
1st and 2nd gear hopping (It feels like it's starving for Air or Gas?) shadowone Mechanical Problems & Technical Chat 21 08-18-2006 11:37 AM
starting in 2nd gear and mpg Tate Civic Coupe And Sedan 22 04-19-2006 06:24 PM
