Old 01-27-2007, 03:52 PM   #1 (permalink)
asndragonboii's Avatar
steering wheel not straight to drive straight
When i drive in a straight line, my steering wheel has to be... lets say 1 degree to the left (dont know exact measurement). If make my steering wheel perfectly straight, the car turns slightly right. Is this normal for our civics?
I know my friend's dodge truck does this also.
Old 01-27-2007, 03:56 PM   #2 (permalink)
I have this problem too. It's not VERY extreme, but its noticeable.
thesandman00 is offline   Reply With Quote
Old 01-27-2007, 03:57 PM   #3 (permalink)
JeShUa's Avatar
swagger so tight
It isnt aligned properly..
that or the road is curved hard.. try it on completely flat pavement
Old 01-27-2007, 03:58 PM   #4 (permalink)
Rems07si's Avatar
Remy
he's right
Rems07si is offline   Reply With Quote
Old 01-27-2007, 04:11 PM   #5 (permalink)
20strong's Avatar
Marcus
Alot of the time when you get a alighnment from someone besides the dealer they will set your steering wheel of to the left just a tiny bit so that when you are drivng on city roads (most in my area have a small slope for run off) the steering wheel will be straight. Just some food for thought.
20strong is offline   Reply With Quote
Old 01-27-2007, 04:27 PM   #6 (permalink)
the car is only 7 months old. I've never gotten an alignment
Old 01-27-2007, 04:29 PM   #7 (permalink)
what do you mean? That doesnt make sense to me. Can you elaborate please?
Old 01-27-2007, 04:30 PM   #8 (permalink)
Rems07si's Avatar
Remy
take it back if its broken
Old 01-27-2007, 04:30 PM   #9 (permalink)
MutantCheese's Avatar
2008 NFR S2000
bring it in to honda. They should be able to set it correctly.
MutantCheese is offline   Reply With Quote
Old 01-27-2007, 04:31 PM   #10 (permalink)
Rems07si's Avatar
Remy
you dont need one the car is to new unless you lowered the car or put BIG rims on it
Old 01-27-2007, 04:32 PM   #11 (permalink)
Vince's Avatar
Stephen "Vince" Carter
Roads are built with a downward slope or incline to allow water to runoff from the center to the outer shoulder or curb area. Make sense? Most good roads anyway.
As long as your car isn't pulling to one side or the other, the steering wheel being *slightly*off center is no concern. An alignment check normally runs about $40, if it needs aligned, $40 on top of that = $80.
Vince is offline   Reply With Quote
Old 01-27-2007, 04:34 PM   #12 (permalink)
nope its not pulling to one side. It goes perfectly straight... its just that the steering wheel has to be slightly left in order for the car to go straight
Old 01-27-2007, 04:37 PM   #13 (permalink)
Vince's Avatar
I don't think you have a problem, but you can calm your fears for $40.
Old 01-27-2007, 04:41 PM   #14 (permalink)
20strong's Avatar
Marcus
When they do an alignment they straighten the steering wheel. So if the roads are mostly sloped for runoff then they set the steering wheel a little off to the right, so that when you are on a sloaped road the wheel is straight.
Old 01-27-2007, 04:42 PM   #15 (permalink)
Rems07si's Avatar
Remy
they could have put on the wheel wrong
Old 01-27-2007, 04:43 PM   #16 (permalink)
20strong's Avatar
Marcus
It should be that your steering wheel iss just off a little. They will straighten it when they aligne it even though it doesnt sound like you need an alingment. If you do have someone do it make sure to tell them to straigten the wheel out regardless if they have to change any of the alignment angles.
Old 01-27-2007, 04:51 PM   #17 (permalink)
WooooHooooo
darna's Avatar
Ate Vi
i don't think its an alignment issue...
i have the same problem b4 and i mentioned a possible alignment problem to the service tech. they worked on it and found out alignment is ok.
turns out the tie rod ends are loose.
The last time I was inside a woman was when I went to the Statue of Liberty
darna is offline   Reply With Quote
Old 01-27-2007, 09:00 PM   #18 (permalink)
thekurgan's Avatar
Victor Kurgan
Your dealer may swap the left tire for the right tire to see if it's a defective tire as well. So if it pulls to the left after they do that, then the tire(s) are defective. In some cases, switching the tires for another few hundred miles will correct the pulling as the tire wears.
More food for thought. Good luck.
thekurgan is offline   Reply With Quote
Old 01-27-2007, 09:07 PM   #19 (permalink)
Vince's Avatar
He stated that the car doesn't pull to either direction...
reading > u
Old 01-27-2007, 09:07 PM   #20 (permalink)
Vince's Avatar
Please stop talking.
Leather Steering wheel installed K757 Inside and Out 24 08-25-2007 10:28 PM
Suede steering wheel cover! xtv-sidecar Inside and Out 10 10-10-2006 10:03 PM
Switching Audio Modes on EX steering wheel question... koreth Civic Coupe And Sedan 0 10-10-2006 05:25 PM
My Test Drive Experience- 9-12-06 webby Driving Experience 27 09-27-2005 10:32 PM
