Old 01-24-2007, 12:48 AM   #1 (permalink)
HELLPPP!! Manual tranny problem
ok well when im in gear and lets say im cruising at 40 in 4th gear n then i press down on the gas, the RPM of the car jumps from 2500 to 5000..what do you think this could be?!?!?!?!
dyactayo is offline   Reply With Quote
Old 01-24-2007, 12:54 AM   #2 (permalink)
articsilber323's Avatar
are you sure it is in 4th gear complety?
do you have you foot on the clutch pedal
sounds like a slipping clutch
articsilber323 is offline   Reply With Quote
Old 01-24-2007, 01:17 AM   #3 (permalink)
MordeKyle's Avatar
hmm, do you drive with your foot resting on the clutch? if you do that could cause the throwout barring to wear out. could be a possibilty
MordeKyle is offline   Reply With Quote
Old 01-24-2007, 01:22 AM   #4 (permalink)
Mattzilla's Avatar
Matt
sounds like your clutch is slipping.
Mattzilla is offline   Reply With Quote
Old 01-24-2007, 01:48 AM   #5 (permalink)
mO 64 StAnG 06's Avatar
So you're in gear... And you press the gas and your RPM's go up. Mabye it's cause you pushed the gas causing you to accelerate?
mO 64 StAnG 06 is offline   Reply With Quote
Old 01-24-2007, 01:54 AM   #6 (permalink)
Mattzilla's Avatar
Matt
Uh, this isn't an automatic, hence the thread title "Manual tranny problem". Therefore, the RPM's should NOT jump up when you press the gas. :face-icon
Nice try with the sarcasm, but if you're going to pick on someone, you should at least try to be logical in the process.
Old 01-24-2007, 02:10 AM   #7 (permalink)
BATANG CITY JAIL's Avatar
unless you shift to high gear then it is jumping..
Old 01-25-2007, 02:15 PM   #8 (permalink)
Mattzilla's Avatar
Matt
Right, but that has nothing to do with his situation.
Problem with Pioneer P880PRS install nuked99 I.C.E., Electrical, Security, & Navigation 2 11-13-2006 12:24 AM
Serious tranny problem Corpsman Water Cooler 11 11-04-2006 01:09 AM
tranny noise Remmick69 Mechanical Problems & Technical Chat 3 09-02-2006 01:43 AM
Need a suggestion b4 i buy the si.. Tranny help groundcontrol_06 Garage 13 08-14-2006 10:24 AM
HELM manual available for 2006 Civic Si skittleslegend Civic SI 9 04-19-2006 02:29 AM
