Old 01-22-2007, 01:49 PM   #1 (permalink)
O6 Si's Avatar
Luisē
having problems with 1st
when i stop at a light or w/e and i have it in N then go to put it in first it kinda stops me half way. I usally have to play with it a little to go in. Any idea what could be wrong? any help please Thank
O6 Si is offline   Reply With Quote
Old 01-22-2007, 02:06 PM   #2 (permalink)
Hidy Ho Neighbor
GeezerSi's Avatar
-> Ken
My 1st gear is fussy when I come to a light, but only before everything is warmed up (still cold). After a couple of miles it's fine. I plan on switching over to the Amsoil MTF fluid soon. That should help.
GeezerSi is online now   Reply With Quote
Old 01-23-2007, 12:00 PM   #3 (permalink)
O6 Si's Avatar
Luisē
thnx greezer, bump for more comments noidea wats wrong here?
Old 01-23-2007, 12:22 PM   #4 (permalink)
solsi06's Avatar
My Si doesn't do it by my 94 del sol does and when I need to put it in first I just push the clutch in twice and it slips right in. So try doing that, it works for my friend's cars to but I would go to the dealer and have them check it out. Maybe they can replace the syncrose or tell you if something is wrong. But i would try double clutching first.
solsi06 is offline   Reply With Quote
Old 01-23-2007, 12:29 PM   #5 (permalink)
O6 Si's Avatar
Luisē
yea syncs was only thing i could think but it dosent grind or anything like that but it does seem to go in a lil ezer if i give it a lil gas usto do it on my 4wheeler too
Old 01-23-2007, 01:48 PM   #6 (permalink)
Camry Loverz
AbsoluteGG's Avatar
Steven
same thing on my lx 5speed coupe. i usually just take the clutch out and put it back and and it will slip in a little smoother. im gonna take it to the dealer on thursday.
AbsoluteGG is offline   Reply With Quote
Old 01-23-2007, 01:59 PM   #7 (permalink)
hatchbac_smokin_you's Avatar
try this as well.. since 1st and 2nd are in the same line.. go to second first.. and then slip it into first..it is the way it is layed out.. try downshifting as well it helps.. look at the graphic here on this site.. gives you good info on tranny's (not that kind..lol) works for me! but when in doubt take it to the dealer...
http://auto.howstuffworks.com/transmission.htm
hatchbac_smokin_you is offline   Reply With Quote
Problems with 8th gen civic dmx Mechanical Problems & Technical Chat 2 11-13-2006 12:45 PM
Problems cazzerz Civic Coupe And Sedan 12 10-18-2006 02:07 AM
Minor problems Nathan Mechanical Problems & Technical Chat 9 09-17-2006 02:04 AM
Anyone have problems with the headrest? iVTEC Mechanical Problems & Technical Chat 9 05-01-2006 01:33 PM
Problems With Waxing Kabs Inside and Out 11 03-23-2006 06:37 PM
