Old 01-19-2007, 03:35 AM   #1 (permalink)
92 honda civic motor just died helpppppppppp
hey guys have 92 civic with the stock motor with 140.000 thousand miles on it and it is a 5 speed,anyways i was driving home tonight going 35mph and all of sudden the car just died,i waited a couple minutes and turned the car over it turned over just find but didn't start,so i waited another 15 minutes same thing,so i waited another 30 minutes the car started but then died a couple seconds later,any ideas?thanks
jtchevy355 is offline   Reply With Quote
Old 01-19-2007, 03:44 AM   #2 (permalink)
nocturnal_si's Avatar
Maybe cause its a 92 with 140K miles on it!!! hahaha J/K.
Gas?
nocturnal_si is offline   Reply With Quote
Old 01-19-2007, 04:42 AM   #3 (permalink)
Dwn4nythng's Avatar
NorCal Meet Organizer
main relay, their only 25 bucks at honda. The main relays go out often on Hondas
Dwn4nythng is offline   Reply With Quote
Old 01-19-2007, 05:09 AM   #4 (permalink)
peenoySI's Avatar
Christian
igniter coil...?
peenoySI is offline   Reply With Quote
Old 01-19-2007, 05:11 AM   #5 (permalink)
UncleSid's Avatar
Sid
when an engine is turning over but not firing....check these things first...1. is it getting fuel? 2. is there spark? 3. is there compression in each cylinder?...
UncleSid is offline   Reply With Quote
Old 01-19-2007, 05:57 AM   #6 (permalink)
Time for a K-swap....
I'd check either the main relay or the distributor cap.
Old 01-19-2007, 06:13 PM   #7 (permalink)
Robert McMillion
My 1992 DX hatch had 360,000 miles before i had to change the engine....i love my hondas :)
92&06 CIVIC DXs is offline   Reply With Quote
Old 01-20-2007, 01:48 PM   #8 (permalink)
Almost definitely the coil. Happened to me on my '94.
NoiseGoth is offline   Reply With Quote
Old 01-20-2007, 02:23 PM   #9 (permalink)
Black_civic_Si's Avatar
Originally Posted by peenoySI
igniter coil...?
yea it might be a ignition coil. Depend on the weather, happen to my friend car. Wouldn't start if it was too hot but will start if it cold. Take the starter to a local tester.
Black_civic_Si is offline   Reply With Quote
Old 01-20-2007, 02:36 PM   #10 (permalink)
BoneStock's Avatar
Tomz
I have a used engine you can swap out with.
BoneStock is offline   Reply With Quote
Old 01-20-2007, 06:46 PM   #11 (permalink)
t('.'t )
m1k3's Avatar
might be a fuel pump problem if none of the other suggestions.
GL
06 FG1 LX MT
AEM CAI | Magnaflow Cat-Back | Comptech SS | TWM Bushings | Eibach Prokit | Enkei Evo 6
m1k3 is offline   Reply With Quote
Old 01-21-2007, 01:14 PM   #12 (permalink)
udumkid's Avatar
Rene....
Check the main relay(inside red circle).to do this listen to a click located near hood release lever once you turn the key to accesories.if you did not hear anything then is your relay.
check the fuel pump. remove the rear bottom seat,have some one turn the key to accessories and you should hear something.(fuel pump underneath this lid)if there is no sound,then its your fuel pump.
Check for spark by using this tool found in http://www.sjdiscounttools.com/kdt2757.html( you can purchase it at your local autopart store also)if no spark then either the ignition coil or the distributor might be bad.
add to my rep if this helped you
udumkid is offline   Reply With Quote
Old 01-21-2007, 01:37 PM   #13 (permalink)
spocheld's Avatar
Jeff
One thing that happened to me once was the alternator went out in my camaro, it would turn over but not start.
spocheld is offline   Reply With Quote
Honda Civic Type R Europe. RODSCIVIC Garage 45 09-16-2006 02:19 AM
Official 2006 Honda Civic SI Pricing Released webby Honda Industry News 20 12-11-2005 01:16 AM
2006 CIVIC SI WINS THUNDERHILL!! 2fast4u2 Civic SI 5 12-08-2005 02:17 PM
honda at thunderhill Abolition Civic SI 2 12-06-2005 11:32 AM
2006 Civic Detailed Report webby Garage 2 07-06-2005 11:25 PM
