Old 01-19-2007, 02:54 AM   #1 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Exclamation shift cables.
is there a away to make them tighter..?
Old 01-19-2007, 03:07 AM   #2 (permalink)
MADDOGSI's Avatar
Scotty
not sure what you mean. explain a bit
MADDOGSI is offline   Reply With Quote
Old 01-19-2007, 04:46 AM   #3 (permalink)
The cable bushing set from Corsport or SpeedSource will take out alot of the play associated with the stock rubber bushings that the cables use. I was told the cables are non-adjustable.
DumbasSi is offline   Reply With Quote
Old 01-19-2007, 02:53 PM   #4 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
well i cant engage my reverse gear so i now have no reverse and i think its because when i was installing my shifter cable bushings i broke the pice that holds the wire to that one clamp.
Old 01-19-2007, 03:08 PM   #5 (permalink)
MellowGato's Avatar
Who needs to go backwards anyway?
MellowGato is offline   Reply With Quote
Old 01-19-2007, 03:10 PM   #6 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
i do. last night after i got off of work i couldnt get out of my parking space. so then i pushed it out. plus now gear 2 4 6 are really short. when im at like 6k in 1st and then shift to 2nd it wont grab.
Old 01-19-2007, 04:04 PM   #7 (permalink)
MellowGato's Avatar
Oh, thats not cool.
Did you try putting the original parts back on?
I have not yet done the short shifter/bushings swap, so I am not exactly sure what can be done. Sorry
Old 01-19-2007, 05:01 PM   #8 (permalink)
MADDOGSI's Avatar
Scotty
SO you broke the u-clip the holds the cable in place. You will just have to get a new clip from Honda.
Old 01-19-2007, 05:48 PM   #9 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
not the u clip but the plastic part thats with the u clip.
Old 01-19-2007, 05:58 PM   #10 (permalink)
MADDOGSI's Avatar
Scotty
http://www.thehondapartsstore.com/he...ll&vinsrch=yes
Here is a link. which part. I dont recall any plastic pieces.
Old 01-19-2007, 06:00 PM   #11 (permalink)
MADDOGSI's Avatar
Scotty
and here is the part the the cables go to.http://www.thehondapartsstore.com/he...ll&vinsrch=yes
Old 01-19-2007, 06:15 PM   #12 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
the part in the middle f #7 and m6. inside that little boot theres a plastic pice that attaches to the u clip part. now i looked at it and that is the problem .
Old 01-19-2007, 11:23 PM   #13 (permalink)
MADDOGSI's Avatar
Scotty
ok so it is the plastic cable end itself that the u clip slides over to secure it to the cable stay bracket on the trans.If so. thats a complete cable replacement. Ouch!
Old 01-20-2007, 02:48 AM   #14 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
exactly but for now i will try to concoction somekind of something to fix it.
Old 01-20-2007, 02:37 PM   #15 (permalink)
MADDOGSI's Avatar
Scotty
^^ try and go to a parts store and get 2 large plastic zip ties.put one over the other in a x cross pattern and tie the cable to the stay bracket.Might be enough to get you by.
Old 01-20-2007, 04:24 PM   #16 (permalink)
MellowGato's Avatar
Zeuceone,
can you please explain what happened that caused that part to break?
The reason I ask, is because I want to do the SS and bushings mod, but now I am afraid of breaking my car...
Thanks
Old 01-20-2007, 04:33 PM   #17 (permalink)
JeShUa's Avatar
swagger so tight
meh.. I say take it to honda and get the original part.. dont let it get out of hand and cause further problems
Old 01-21-2007, 12:02 AM   #18 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
i bought some pipe to make the cable straight again but it only helps for so long. when i was installing the cable bushings i pull the wire piece to high and it snapped. all i needed to do wash use a screwdriver to remove the old cable bushing.
Newest Shift Knob From TWM! TWM Performance TWM Performance Short Shifters 7 03-27-2007 03:42 PM
Civic 1.8L paddle shift in Singapore tanwn Civic Coupe And Sedan 12 09-29-2006 11:51 PM
Does Augerresources shift boot fit Coupes? joonoo Inside and Out 4 09-03-2006 07:21 PM
Voodoo Knob and Shift Boot Solution Fixer Inside and Out 2 08-17-2006 11:38 PM
Shift boots hoanger Inside and Out 10 06-20-2006 01:03 PM
